1969 FJ55 Toyota Landcruiser
KERRDOG
Local listing, not mine. Cool rig with lots of potential...
http://oklahomacity.craigslist.org/cto/5550778655.html
Rare 1969 pig that I have had for 16 years. Bought in Colorado Springs from the original owner with 84,000 original miles. Many, many upgrades and modifications. What parts that have not been replaced have less than 90,000 miles. With about 100 of these registered, this is in great condition. Just don't drive it much and don't have time to complete it. It has been parked inside almost the entire time that I have owned it.
Only 700 miles!
Newly rebuilt numbers matching straight 6 with overbuilt components, cam and head.
Upgraded Webber 2 barrel, coil, hoses, pertronix, alternator, fuel pump, regulator, air filter, switched to screw on oil filter instead of oil bath, new battery, skid plate oil pan [rare], new motor mounts, all new body mounts all the way around, list goes on, new coated gas tank and filler neck, etc
Converted from 3 on the tree to a newly rebuilt granny gear 4 speed and transfer case out of a FJ60.
New tie rods and steering stabilizer, brake wheel cylinders and drum pads, custom drive shaft and new ujoints.
Lots of rust removal and body repair, a few areas still left.
4" inch spectre lift kit with 2" shackle lift on 33"x12.50 pro comp mud terrains on aluminum 17" ultra wheels, having full size matching spare.
Buckets seats in front.
Including in the deal about $1,000 worth of parts, some which are really hard to get.
Wheel and axle bearings
Hub rebuild kits, gaskets
Full carpet kit, didn't install yet because it needs door weather stripping
New rear tailgate weather strip and glass channel
Full non dented tailgate with another window motor, the window in rear still works
Extra door handles, visors
What it needs to be complete:
Headliner, did diamond plate door panels, and hot rod batting in roof but no headliner
Drivers door needs adjustment, all other doors close perfect
Door weather stripping so carpet can be installed
The fuel gage needs to be messed with, doesn't register
Other potential upgrades if you want to get crazy, air conditioning, power brakes, & power steering
This a solid rig that is extremely rare. It is not perfect, but I have way more invested than I am listing. $8,900 obo. 918.eleven.forty-four.
