Source3
Sale Pending
Selling my FJ40 on Craigslist.
http://westslope.craigslist.org/cto/4000138742.html
For Sale Early 1973 FJ40 with early 1979 Engine/Tranny swap.
Price: $9,600 (US)
Odometer: 82717.9
Location: Durango, Colorado since December 2012. Spent most of its time in New Mexico.
Phone: 9 seven zero - five 7 zero - nine five three 5.
Reason for selling: Bought an FZJ80
This is a 9/72 (early 1973) FJ40 with a 1/79 (early 1979) 2F engine, 4spd Tranny, and Power Steering.
Original paint except where I added an aux fuel door, changed location for the shifter hole for the 4spd, and filled misc. antenna holes.
All glass is original. A few stars in windshield but not in line of sight. No cracked glass.
I built this for a mild wheeling rig and semi-daily driver. All mods where for driveability and human comfort.
Have all receipts for items purchased. Used OEM parts as available. Did work myself or with help from the local Land Cruiser community.
Driveability is excellent. I would have no problem driving across country.
Slideshow of more photos located at: http://s1134.photobucket.com/user/source3comp/slideshow/FJ40 For Sale
Build thread is located at: http://forum.ih8mud.com/nm-high-desert-cruisers/319684-ol-jenny-build-thread.html
Mods:
* Engine/Tranny swap (F engine to 2F engine) with power steering.
* Tranny/Transfer Case Savers (parts from Valley Hyrids)
* 2.5" Old Man Emu (OME) Heavy Duty Lift (shocks and springs). (Cruiser Outfitters)
* New OEM gas tank and sender.
* Auxillary Gas Tank (Northwest Metal Products; 22.5 US Gallons) with Pollak fuel selector valve (switches tanks and fuel sender; stock fuel gauge shows accurate reading for selected tank)
* 33x9.5" BFG AT KO's
* Brake booster from a 82 supra and brake master cylinder from an 80-series (new-refurbished)
* Centech AP-2 auxillary fuse panel
* Roundeyes (RCH100-2) 7" Conversion Headlights with ARB wiring loom
* Removed rear jumper seats and custom built shelving (have original jumper seats).
* Partially de-smogged by previous owner (still needs to be finished up)
* Rebuilt carburetor by Mark's Offroad. Carb has the high altitude jets.
* Ported vacuum F carb for 2F vacuum advanced distributor. Work done by Mark's Offroad.
* Replaced distributor. Original 2F dizzy had leaking diaphram. Purchased from Mark's Offroad.
* Four wheel disk brakes. Front - 1976 FJ40. Rear - Monte Carlo with caliper bracket from LCR 4 Wheel Drive
* Replaced brake lines with custom fitted stainless steel.
* Warn 8274 Winch.
* 4Plus Deluxe 48-inch winch bumber
* Diehard Platinum P31 Battery (Purchase Date: 05/22/2010)
* Replaced door weatherstrip with OEM (driver, passenger, rear hatch)
* Replaced all drive belts and seals during engine/tranny swap.
* Scat Rally Recliner Seats (#80-1000-51L(R)) with Scat brakets (Driver and Passenger)
* Replaced body mounts with Energy Suspension kit from Cruiser Outfitters
* Replaced U-Joints, Balanced Driveline (Cut and trim driveline for 3spd to 4spd tranny swap)
* Wheel Alignment by Chets (Albuquerque, NM)
* New exhaust after engine swap
* New radiator and thermostat during engine swap
* New keys cut from VIN Number. Keyed aux fuel door to match existing locks
* Front floor insultated floor mats and cargo mat (CoolCruisers)
* Kill switch. Used a DPDT switch to kill engine with or without blinking LED
* Replaced dashpad with Dashman's Dashbox.
* Replaced tie rod ends (777 ends from Cruiser Outfitters)
* Replaced steering pivot assembly with OEM parts
* Replaced left and right defrost hoses (Spector Offroad)
* Modified the tranny for 2Lo gearing (see build thread for details).
* Replaced driver and passenger window felt
* Replaced tail light lenses.
Price: $9,600 (US)
Odometer: 82717.9
Mods:
* Warn 8274 Winch.
