1975 Pinzgauer 710M
schuy2147
http://www.flickr.com/photos/97645474@N04/
Unfortunately I have to part with my newly acquired Pinz. My decision to pursue further education is the driving factor for the sale. I'm selling a 1975 710M. I purchased the Pinz with 42298 km and it currently reads 44734 km. I purchased it back in November with big plans of travel and adventure. Life, however, has taken a different path at the moment and I must part with it. The previous owner had if for about 12 years. This Pinz has been meticulously maintained and cared for. It is pre-wired for (2) 12v batteries to be wired in parallel. It has 3 inverters, 12v power up front for cigarette charging use. There are Rancho 9000 adjustable shocks up front. The truck has custom, fold up panels in the rear that will keep the entire vehicle secure. There are door locks installed as well. The CB works but needs to be tuned. The cd player is ready for speakers to be mounted. The rear is outfitted with a buddy heater, surround sound, and LED lighting that will work when the batteries are installed; or, they will also work when connected to an extension cord from a house or trailer site. It has two battery tenders hard-wired in for battery maintenance. The entire truck is outfitted with insulation and foam padding to eliminate noise and vibrations. I believe the driveline was also balanced. Comes with the original shovel and axe. Everything is in good working order. I would prefer local pick up only.
CONS: The parking brake needs adjustment.
The right rear axle boot is a replacement but has a small tear; I put a bit of RTV on it for a temporary fix.
I'm located in New River AZ. $16,000 obo.
stevo
Pinz 710M
Howdy,
Sorry that I am so late in a reply to your post, I just came across it this A.M. I too, have a 710M, and was wondering if you still had yours. While I am not in a position to purchase another at this time, I would be very interested in learning about some of the mods you have made to your truck. I see that you are in Arizona (probably), while I am currently in Ca., my truck is in the Prescott area. I would very much like to hear from you. Please P.M. me.
Cheers, Stevo
dhuss
