1978 GMC/Chevy 4x4 4wd Van in Portland
joshgreen454
I am selling my 1978 GMC 4x4/4wd van for $5000. It is located in Portland, OR and I have a clear Oregon title and the tags are currently still good and the van runs/drives very well. It can be driven home, no need to trailer it back. It was converted to a true 4x4 with solid front axle by a company called Pathfinder. They fabricated an adapter and all the front suspension parts for their conversion. I replaced some of the wiring to the starter and the van has a new radiator hoses, ignition, water pump, thermostat and starter. There is a roof vent already installed and a custom trailer hitch (looks homemade, or maybe it was part of the Pathfinder conversion?). I stripped the van down and collected everything to make it into an adventure rig, but started on another project instead.
Price includes van & all additional parts listed below.
I can send more pictures if there is anything specific that you want to see, just let me know.
Not really looking for trades, but would consider partial trades of 7-9k dual axle trailer, 44" tires, 60-80 gallon single phase air compressor.
Specs:
- Chevy 400 small block with aftermarket intake & Edelbrock carb & dual exhaust (2 chamber Flowmaster mufflers)
- Turbo 350 automatic transmission
- Ford NP205 transfer case with custom Pathfinder adapter & shifter
- 8 lug Ford Dana 44 front axle with disc brakes (driver side diff)
- 8 lug 14 bolt full floating rear axle with posi
Additional parts:
- (5) Firestone 265/75/R16 tires
- Warn winch with control cable & mount
- Aftermarket hitch (pulled from donor van)
- Steering column (pulled from donor van)
- (2) rear barn doors with good glass & painted to match
- Sliding side door with good glass & painted to match
- Driver door with good glass & painted to match
- New weatherstriping for all doors (still sitting in box from LMC)
- New marker/side lenses (still sitting in box)
- (4) Captain chairs (2 matching sets) - nice heavy duty base brackets that swivel
- Rear bench seat
- Complete factory A/C set up (pulled from donor van)
- Complete dash (pulled from donor van)
- (3) Dog houses (engine covers)
- Complete hydroboost brake set up (pulled from donor van)
- Roof mounted A/C units (pulled from motorhome)
- Propane heater (pulled from motorhome)
I have a few boxes of misc hardware/bolts/handles/mirrors/etc that you can have as well.
Finish building this please!
4xCoffee
