1979 Dodge W200 First Gen Crew Cab 4x4 12 Valve Cummins 25k
Diesel 80
Hello,
The price was set at $19,000 below what it cost to get the truck to the point it's at. Truck is 80% complete. I'll list everything it comes with and what has been done. This has been my baby for 6 years and pains me to fathom the thought, but health and priorities have shifted. Time to simplify life. The Build is very extensive and would cost a fortune to replicate... not to mention time. It's so close to being a driver. Any questions, please feel free to message me. Sorry that the pictures aren't in chronological order, but you can get an idea. ALL the skid plates and under protection for fuel tanks have already been powder coated black. Front and rear bumpers are plumbed as air tanks and have been powder coated. The entire bed and stack etc has been powder coated as well. Has on board air via the Haldex attached to the block (like a bus). Truck is located in Southern California. 25k obo. I can be reached at axxisoffroad@gmail.com. Thank you for looking.
-1992 CTD front clip
-1992 CTD front doors
-Frame has been squared, boxed, jig holes filled
-Steering gear mount reinforced
-JCWhitney weatherstrip kit
-Energy Suspension cab mounts
-Custom made inner fender liners
Front Axle
-ARB RD21 airlocker
-4.88 r&p
-8' braided ARB airline
-New bearings and seals
-New brakes
-Braided caliper lines
-Lube Locker gasket
-Kryptonite diff. cover
-NWFabworks High Steer
-ARP stud kit
-1410 straps
Rear Axle
-ARB RD35 airlocker
-4.88 r&p
-20' braided ARB airline
-new bearings and seals
-new brakes
-braided caliper lines
-Lube Locker gasket
-1410 straps
-Missouri Offroad Axle Truss
-Rear brake disc conversion - not installed
Motor - 1992 CTD 130,000 miles
-Killer dowel pin killed
-New front main seal
-New rear main seal
-New valve cover gaskets
-Valves adjusted
-2nd Gen. low pressure lift pump
-Bully Dog fuel pin
-New HX35 Turbo
-4" ceramic coated downpipe
-Horton 2nd Gen. Fan
Transmission - 1992 A518
-2nd Gen. flexplate
-TCI Torque converter
-Hughes Performance shift kit
Fuel tanks
-2- 34 gallon Ramcharger tanks
-3/8" pickups
-Pollak Motorized Fuel Tank Selector Valve
-Jaz Fuel Cell fill
Transfer Cases
-NP205 out of '92 CTD, shift rails Machined for triple stick
-NP203 out of '79 W200
-Both new seals
-PolyBushing transfer case mounts
-billows vent
-NWFabworks - Billet kit
- 32 spline input gear
- doubler kit
- side mount kit
-Air cylinder shift components
Front Driveline
-High Angle Long slip 3" tube
-1410 ujoints with straps
Rear Driveline - 1992 CTD
-High Angle E-Brake
-balanced
-new carrier bearing
Steering
-Borgeson Steering Shaft
-West Texas Offroad Hydro Assist
-tapped steering gear
-Sauer/Danfoos Power Steering Pump with Stirling Relief Valve
Rims
-Stazworks Double Beadlocks 17x11 Quantity 5
-Powertank Monster Valves
-DynaBead Valve Stems
-No Tires-Just Rollers-
Seats
-PRP Daily Drivers Xtra wide
- lumbar support
- sliders
-Crow V-Harness with pads
Suspension
Front
-SkyJacker D600S 4" leaf springs
-SkyJacker DA60 Extreme shocks
-Energy Suspension bushings
-5/8" greasable bolt
-2" shackle extension
-1 1/2" front spring frame bushing upgrade
-ubolts flipped
-grade 8 bolts, nut, washers
-Timbren A170-55 with cans
Rear
-SkyJacker DR40S 4" leaf springs
-SkyJacker DA40 Extreme shocks
-4"shackle flip
-ubolts flipped
-Timbren A535-55 with cans
Misc.-
-Vanco Hydroboost
-Haldex air compressor with relief valve
-Grade 8 Fasteners throughout
-Tuffy Series 2 Security Console with armrest and rear drink holder
-One off front bumper with 7.5 gallon air tank
-One off rock sliders
-One off roof rack
-One off tubed bed
-One off skid plates
-One off rear bumper
-One off cage and dash
-One off crossmembers for transmission and transfer cases
-One off dual battery box
-Conversion van rear fold down seat
-4 LightForce Blitz lights
-4 LightForce Stryker Lights
-TMax 12000 winch
Second Skin Audio soundproofing material
-3 Shop Pack Damplifier Pro
-10 sheets Luxury Liner Pro
-2 gallons Sprayable Spectrum Vibration Polymer
-3 Second Skin Contact Spray Adhesive
-1 undercoat spray gun
-150' roll foil insulation tape
Timbren
This isn't something you see daily, gorgeous truck! Love that Timbren could be on this build!
huntsonora
Wow! Was this build originally started by a guy from the Dakotas? If not it’s so close but that had to be close to 10 years ago.
I always drooled over that truck. Amazing work if it’s the same truck. GLWS
DanoWall
