1980 280GE SWB Barn Door Truck FOR SALE
unimog2450
1980 Mercedes Benz 280GE
Short Wheel Base Barn Door
VIN 46023217006445
Colorado Beige (paint code: 1470)
Manufacture date: June 03, 1980
Engine: M110E 2.8L I6, 156 hp, 166 lbft (4250 rpm)
4-Speed manual with front & rear locking differentials
$29995.00 OBO
Approximately 40K miles from new. Three owner truck imported into Oregon early in its life following initial purchase in Germany. Oregon owner tackled the Federalization on his own (I have original paperwork). Sold to Maryland individual and used sparingly over six year ownership. I purchased in June 2015 with intention of full restoration/modification due to such good original condition, but chose to keep as-is aside from suspension, wheels and tires. Reason for selling? To fund other projects (house, son’s college tuition, etc) but want this to go to a good home. Truck can also be seen on www.ClubGWagen.com classifieds with lengthy thread of comments. Not CARB compliant unless someone wants to spend a ton of additional money to smog certify in California.
A number of maintenance items were needed in order to bring back to reliable running condition as it sat so long in storage. Namely brake system, fuel system all the way to injectors. Truck needed to pass emissions to Register/plate it here in Colorado. These items were corrected and vehicle runs well. All repair/maintenance was performed by Mike Hoover of Hoover Mercedes, an independent repair shop. I can argue that of all the Mercedes shops I’ve used on 8 different Mercedes vehicles over the years, Mike is by far the best in Colorado (IMHO). He has 25 years of Mercedes experience and named Master Guild Technician numerous times. If he signs off on a vehicle leaving his shop, rest assured it was repaired right.
Other items added to the truck during my ownership:
• New brake line system
• New MB plastic fuel tank and lines
• Brake master cylinder including reservoir
• Brake slave cylinder
• Eibach ORC springs
• Koni SPX shocks
• Hella fog lamps
• Turn signal guards
• Headlight guards
• Borbet fender flares
• Window tinting
• Tortion bar frame re-mount to correct driveline balance with the added suspension height
• AMG G55 wheels (plastidipped)
• BFGoodrich 35/12.5r18 tires
This is a 37 year old UNRESTORED truck and I represent that fact openly. No surprises, just an honest original vehicle that presents itself very well. Previous ownership showed care in maintenance and basic preservation. Including minor rust repair around the rear doors—a process that involved welding in new metal and painting to match—but otherwise original bodywork and paint. Exhaust system replaced in Maryland and near new condition. Minor corrosion near a rear pinch seam. Interior is near perfect with original Becker radio. Minor vinyl abrasions at driver’s seat base where cushion deforms when getting in and out of truck, otherwise excellent upholstery condition. I was involved in a rear end collision back in November 2016 and had 2 vehicles impact the rear of the truck. Fortunately, the only areas effected were the left bumper and steel fuel tank. Replaced tank with new style factory plastic version directly from S-Tec manufacturer in Austria. Bumper bracket including left mud flap assembly were slightly bent. Bracket welded with new matching material and new bumper installed. Did not replace mud flap assembly.
Turns heads every time I drive it. Questioned in parking lots regularly. Great conversation piece!
$29995.00 OBO as it sits or $27500.00 minus AMG wheels and BFG tires. I have the original steel wheel set with near new tires that I can put back on or sell separately. Shipping at buyer’s cost, but I can arrange if needed.
Options:
A70 & A71 – front & rear axles diff. locks
C70 – two-part divided rear bumper
E40 – 7-pin trailer plug socket
E63 – Becker Europa Cassette
F46 – headlamps washers
F66 – lockable glove compartment
G75 – differential gear speedometer shaft
H20 – heat-insulation glass all round
J33 – clock
J38 – tachometer
L12 – halogen headlamps
L16 – halogen fog lamps
L18 – rear fog lamp
M74 – underbody protection for engine & radiator
Q53 – low mounted ball-head type trailer coupling
Q58 – front tow-off coupling
R69 – spare wheel carrier, swivel type
S20 & S26 – folding front seats
S30 and S32 – headrest for driver and passenger seats
S55 – folding rear seat
S64 – safety belts for rear seat
V18 – upholstery color black
V22 – upgraded version of the interior trim
V34 – padded grab handle and instrument panel
V47 – central tray with hot-air guide to the rear
Y10 – first aid box
Y44 – warning triangle
Serious inquiries can PM me directly. Provide phone number/email address and I will respond promptly.
ionyota
Great truck!!
Can you past a pic of the stocks rims and tires?
With the lift, how does it look with a tire size closer to stock? Or something closer to 33" tall?
Do you notice much difference in how the truck accelerates, brakes, shifts with the 35" tires?
unimog2450
Thanks all for the comments!
I'll get a photo of the original truck with 16" steel wheels, no lift and no fender flares. Truck would look really tall with stock/near stock wheels/tires and the lift (shocks/springs) adds another 4+ inches to overall height.
Stock wheels and narrow tires definitely gave the truck more agility and nimble steering on road, but the larger wheels/tires ride quite well. This truck isn't winning any acceleration contests. I did not notice any real change in off the line acceleration and the BFGs track straight and true. When I had the brake system rebuilt, I noticed a vast improvement stopping, but the suspension was changed out at the same time, so no way of knowing how this particular truck braked when new.
The first 2 exterior photos used filters, but the official factory color is Colorado Beige. No copper, just gloss tan.
unimog2450
Here is the truck in original configuration. I do not have any shots with the stock wheels/tires with the new suspension shocks/springs. I think the truck would still look really good with the stock 16" wheels, but spacers would now be needed to bring them out to align with the wider fender fender flares.
Haf-E
Did it sell with the original Gwagen steel wheels - if not - I am interested in them. Let me know!
unimog2450
I still have the 4 original steelies. Message me with your email or phone and we can discuss from there. I can provide additional photos.
xander69
