Its a sweet truck, of course I am partial to IH stuff and own a few of them. I am willing to bet it has pretty low axle gears so putting a diesel in would mean you would need to change the axle gearing also in order for it to be able to cruise at anything close to safe speeds. I have a 1972 Loadstar 4x4 bus that I have a cummins to replace the rod knocking 345 with but am still working on getting the gearing options worked out so I will be able to drive it at anything close to hiway speeds. My bus has a 345 V-8 with a four speed manual transmission 1-1 in forth and either 6.17 or 7.17 axle gears. Its got 900x20 tires and I tried to do 55 mph when I was bringing it home, it made it half way under its own power before I had to park it and get it towed the rest of the way due to a rod knock.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
