1981 Scrambler Crawler in VA 31.5k OBO or 23k...
OK, Final bump before this goes under the knife. I'll be pulling the go fast motor parts and putting rebuilt stock heads back on with edelbrock intake and Crane Roller 1.6 roller valve train,but basically back to stock compression on a .030 flat top piston motor....sostillplenty of ponies...just not the crazywildkind. I'll be swapping the built 1 tons for rebuilt 4:56 geared HD 44front and 14 bolt rear with reardgetroit...both rebuilt and have HD diff covers and all 100% new disc brakes all around. I'll be removing the winch and replacing the Genesis Dual Bettery kit with a single Yellow Top in a Motobilt box. I'll likely pull the beadlocks and replace the wheels with a black steel 17" soft 8. Basically you have a well built and fun and fast wheeling and street Jeep for way less...around $23,000.
With that being said...if anyone wants it as it is with the way overbuilt everything, all the trail spares like extra driveshafts, TRE's, U Joints, bikini tops (2), Soft doors, LED lights and stuff...I'll make a sweet deal if I keep it together and save me all the work to put the new parts on!!!
BUMP.....going wheeling next weekend with the rig as a built 1 ton..so open to offers as it is now, but once I get back...I'm swapping the deadlocks for new 17' steel wheels, pulling the winch, replacing the dual battery with a single yellow topic a Motobilt box and swapping the axles for a Dana 44/14 bolt combo, rebuilt 4;56, disc all around a rear detroit and HD covers. Price will be $22k firm. Motor will have rebuilt stock heads, since the aluminum Edelbrocks have been pulled.
xander69
