Spotted this tonight, no relation to seller:
http://cgi.ebay.com/ebaymotors/Cars...id=p4506.c0.m245&_trkparms=65:3|39:1|240:1318
Isaac
You are bidding on a very nice Unimog 435 / U1300L German ex- Bundeswehr (special Corps of Engineer edition with PTO and winch!)
The vehicle is in excellent condition and is drivable.
* Built in December of 1982 (DUE TO GERMAN VIN, THE VEHICLE HAD TO BE LISTED AS A 1980)
* 87.000 km (54.062 mi).
* Vehicle totally overhauled in February of 1993 (see picture #10)
* Fast Axles (max speed: ~ 65mph).
* Front Winch.
* Front PTO.
* German Bundeswehr Camouflage Paint.
* NATO MIL tires 70%, with new spare (size:12.5R20).
* Tire changing jack and wrench.
* Cab Lifting Jack-Tool Set.
* Injection Tool Set.
* Bed bows and TWO Canvases - UN-White AND short Camouflage .
Many spare parts:
* 1 x Lift Tool Kit ~$1500
* 1x Injection System Specialty tool kit ~$500
* 4 x Shock-Absorber ~$300 per piece
* 2 x Break Disk ~$200 per piece
* 1 x Clutch ~$200
* 2 x Head light assembly
* 2 x Rear Light Covers
* 8 x Brake Pads (2 x box)
* 3 x Air Filter
* 3 x Oil Filter
* 2 x Fuel Filter
* 4 x Snow Chain
* 2 x Blinker Assembly
* 1 x Multi Function Blinker/ Windshield Wiper Switch Assembly
* 1 x Complete Instrument Cluster (used spare)
* 1 x Water Pump (used – re-manufactured Bundeswehr part)
* 1 x Starter (used – re-manufactured Bundeswehr part)
* 1 x Major Air brake system spare parts kit (~60 Parts)
* 1 x Steering column universal joint spare (new)
* 1 x rear view mirror spare plastic holders
* 6 x Four Wheel Drive System Spare Parts (Shim Rings, etc)
* 8 x spare holding latches (hood.. etc)
* + more
Specifications:
* 3.25m / 128" wheelbase.
* 1.86m / 73" track width.
* Overall 5.59m L, 2.33m W, 2.83m H (220" L, 92" W, 111" H).
* Cargo bed 3.15m L, 2.20m W, 0.50m H (124" L, 87" W, 20" H).
* Curb weight 5'250 kg (11'600 lbs).
* GVW 7'500 kg (16'500 lbs).
* Fuel economy ~17.5 liters / 100 km (~13.5 mpg).
* Fuel capacity 160 liters (42.25 gal).
* Cruising range on highway ~900 km (~560 mi).
* Oil consumption, 1% of fuel.
* Direct injection OM-352 diesel engine + TURBO CHARGER!
* 6 cylinder, 5.675 liter / 346 ci, 7 bearings.
* Power output ~140 hp at 2'800 rpm.
* 8 speeds forward, 4 reverse, all syncro transmission.
* Push button center differential lock, 2 wheel to 4 wheel drive.
* Push button axle differential locks, front and back axles.
* Portal axles with 0.44m / 17" ground clearance.
* Coil spring suspension.
* Up to 20° torsional twisting.
* Power steering.
* 11x20 rims with oversize 12.5x20 NATO MIL tires.
* Air assisted disk brakes for vehicle and trailer (front & rear hook up)
* Air compressor + Tire Inflation hose.
* Raised air intake.
* Forward tilting cab, seating for 2 - 3 persons.
* Removable hood and front grill.
* 24 Volt electrical system with two 12 Volt batteries in sequence.
* Rear pintle connector.
* Military convoy lights.
* Roof hatch.
* Seat belts.
* Locking gas tank cap.
* Front PTO, no hydraulics.
* Service & Operation Manual in German.
* German Army Instruction Manual in German.
* DOT/EPA certified street legal in all 50 states.
* South Carolina and Original German Title.
Isaac
* Front Winch.
* Front PTO.
Many spare parts:
* 1 x Clutch ~$200
* 3 x Air Filter
* 3 x Oil Filter
* 2 x Fuel Filter
* 4 x Snow Chain
* + more
Specifications:
* Power steering.
* Roof hatch.
* Seat belts.
