1985 Toyota 4Runner fully rebuilt 22RE Performance, Marlin Crawler
sweatybandit
I listed this last summer, but pulled the plug when I couldn't bear to sell the truck. Now, I'm moving and don't have the room. My loss is your gain on this mechanically rebuilt 1985 Toyota 4Runner SR5.
Located in Seattle. Asking SOLD
If you are looking - you know and understand the time and money invested and how much of a deal this Gen 1 4Runner is. Previously owned and built by another forum member (v8turbo) who built two of these gems. Build receipts available to serious buyers.
225K miles on odometer. Drivetrain swap completed at 215K miles. I purchased the truck at 216K miles; less than 10K miles on fully rebuilt drivetrain.
SR5, Sunroof, rear heater, power windows, AC, inclinometer, LED Internal lights, LED headlights, Rear Warn power plug for rear winch or jumper cables, Blue Sea power interrupt switch for rear power.
This is not a SEMA build for the show, it's been built to last forever.
The final stage would be to paint, but I like the patina finish and the millennials think it's cool. There is only minor rust on the driver and passenger rear quarter panels. No rust underneath.
Front seats are great and have always been covered. Rear seats were covered since new. New front and rear seat belts. Dash has a crack. All power windows work and have new motors and regulators. Only thing that doesn't work is the rear defroster.
Full Drivetrain Replacement with all new parts. 22RE Performance, Marlin Crawler, ARB, WARN, OEM Toyota, TRD, RCV, Hella, Trail Gear, AllPro, Optima, Blue Sea, Factor55, Rigid Industries, Old Man Emu, ...etc. Only the best used.
Items Replaced/New - Motor, Cooling System(OEM Radiator), Charging System, Starter, Updated AC, Suspension, Brakes, Steering, Exhaust/Muffler,Catalytic Converter, Bumpers, Winch, Lights, Axles, Differentials, drive shafts, transmission, transfer case, Wheels, Tires, Side Rails, Horn, every gasket, hose, belt, OEM Bolts, Etc....
Professional installation by a master Toyota tech that does the motor installs for 22RE Performance in Chico California. Car was shipped to Chico for all mechanical work. Drives like new and will easily last another 225K miles.
BUILD SHEET:
-22RE Performance - Stage 2.5, fully balanced and blueprinted. Revs hard and nothing like a stock 22RE. If you're not familiar, see description by the best 22RE builders: https://22reperformance.com/stage-25-rebuilt-engine
-Marlin Crawler - HD 5 speed with Marlins short shifter kit.
-Marlin Crawler - HD Transfer Case. 4.71 low upgrade
-Marlin Crawler - V6 front calipers, Rotors
-Marlin Crawler - V6 1.5 Bore Master Brake Cylinder
-Marlin Crawler - High Steer with 25MM Pin UPG
-Marlin Crawler - 4.88 Ring and Pinion
-OEM Toyota Dual Diaphragm Brake Booster
-OEM - Alternator
-Old Man Emu 2.5" Suspension kit/Shocks
-Wheelers Off Road Super Bump/Bump Stops on front
-Warn M8000S - Factor 55 Prolink/Offset Fairlead
-ARB - Deluxe Winch Bumper
-Trail Gear Rear Bumper
-All Pro - Sliders
-Offgrid Engineering Custom Dual Battery System - In cab Switch
-Optima Yellow Top Batteries
-Low Range Off Road battery- Box Powder Coated
-TRD - OEM TRD Pro Wheels
-Falken Wildpeak AT3W
-Blue Sea - Below Deck Panel in Rear for USB/Cig power
-Blue Sea - Fuse block for individual fused accessories, dedicated power interrupt, Rear Switch interrupt for Warn Plug
-Spider Trax - Toyota Wheel Spacers
-RCV - Front Axles
-Replaced rear axle bearings
-Rigid Industries - LED Headlights, 2 Aux - Dually Side Shooter's
---Much Much more of OEM parts, OEM bolts, OEM plastic pieces.....etc.
Houie
