Here are the specs on this van. For sale in Bend, OR.
Please contact Andy @ 503-863-1314 or andyferchland@gmail.com. I am posting for a friend and will do my best to handle forum communication, but I won't be able to answer as many questions about the van as he can.
General Upgrades:
Engine:
Transmission:
Transfer Case:
Front Differential:
Rear Differential:
Shocks:
Wheels and Tires:
Other:
General Notes:
General Upgrades:
- New custom roof rack
- Spare tire and hi-jack mounted
- Solar Panel mounted but not connected
- New paint
- Custom Bed assembly with new queen size Lucid 5 Inch Firm Gel Memory Foam Mattress, Hypoallergenic
- Storage below with totes
- New kitchen Unit from Cascade Campers
- 270 degree awning with LED lights
- New upholstery on driver and passenger seats
- Custom vinyl rocker panel graphics
- New floor mats and area mat
- New custom door panels, resilient textured plastic
- New Dash mat, gear shifter, vents
- RV side Battery bank with inverter
- To be connected to solar panel in future
- Custom connection to cab battery for emergency start
- Extra can holders not installed
- Roof mount and back door mount
- 1-5 gal Gas and 1-5 gal. Water tank included
- New exhaust pipe, muffler, tip
- All new rubber seals on all doors
- Windows tinted
- Coleman 12v cooler
- New Mr. Heater
- Illumminated detachable disco ball!
- All new washer fluid system
- Rear brake assembly overhauled
Engine:
- Small block Chevy 400 with R.V. cam – unknown how many original miles
- New Holly Sniper fuel injection system
- New Holly Sniper air cleaner
- New Eldelbrock Performer intake manifold
- New harmonic balancer
- New HEI distributor and vacuum advance
- New plugs, plug wires, wire hold-downs, cap, rotor, belts, oil change
Transmission:
- Turbo 350 3 speed automatic
- Transmission rebuilt less than 1,500 miles ago
Transfer Case:
- N.P. 205
- Transfer Case rebuilt less than 1,500 miles ago
Front Differential:
- Dana 44 ½ ton with manual hubs
- Fairly recent front brake pads, new rotors, brake lines, calipers, new fluid and bearings packed. New u-joints on front axles. Master cylinder and brake booster replaced approximately 2,000 miles ago
Rear Differential:
- Fairly recent new rear brake shoes, drums, brake lines, axles, new fluid and pinion seal. New u-joints on rear drive line.
Shocks:
- New Rancho 5000’s a year or so ago.
Wheels and Tires:
- 6 new 33x10.5x 15 Les Schwab Wild Country XTX Sport tires.
- New Steel Wheels from Discount Tire, New Center caps and lugs
Other:
- Replaced power brakes booster, master cylinder and steering box
- New battery
- Pop-out windows on sides and rear.
- All electric window motors and electric door locks working
- Newer wiper motor
- 4 New LED head lights
General Notes:
- This van was initially purchased from Chevrolet by Bruce Chevrolet in Beaverton, Oregon and brought to Pathfinder where it was converted to 4x4.
- With all aftermarket equipment the van does not pass DEQ and is sold as is. This is not an issue if registered outside of Oregon metro areas (Deschutes and Central Oregon Counties are O.K.)
