1988 Astro Tiger Pop-Top 4WD 77,000 miles - $8000
No Affiliation. Looks super cool and could definitely be a good platform for a build if you strip the interior ( which isn't in bad shape ).
Would be cool to see what someone on here could do with it.
http://siskiyou.craigslist.org/rvs/4743082221.html
Seller says:
For sale in Dunsmuir, CA. 1988 Provan Tiger Chevy Astro pop-top RV. 4WD 77,000 miles. Well maintained with new tires.
Body and roof painted with three coats of Durabak. (No leaks. No waxing!)
Other features include:
--Working air conditioner with many new parts (dryer, hose, etc.). Does not leak. Recently topped off.
--Working cruise control.
--New wheel alignment.
--New headliner./visor reupholster.
--Newer spark plugs with spark plug wires with less than 1,000 miles.
--All interior lights work.
--Newer remote-controlled stereo with mp3 plug-in.
--Replaced speakers.
--New heavy duty, dirt-repelling throw rugs.
--New front auxiliary LED lights.
--New, never used propane tank.
--Large closet (does not have bathroom or shower)..
--Pop-top canvas in okay condition. I repaired one spot. There is one area on the front prop panels used to raise the top that is a tad warped, but still works strong. For some reason the wipers do not return to off position when switched off. Have to manually gauge this.
--4WD works just fine (is not AWD). Has low and high shifter. Recently changed transmission fluid in front case.
--Does not use excess oil or excess transmission fluid. Does not leak oil or transmission fluid.
--Captain's seats are in fair-to-good condition. Very comfortable. No stains.
--Radiator has been repaired and no problems with water circulation/heater..
--77,000 miles.
--Can stand up to 6'2" comfortably when top is popped.
--Brand new tires.
--Brand new rear air shocks.
--2 inch receiver hitch. Can tow up to 4,000 lbs.
--Has small dinette table, which is removable.
--Bottom seats can fold out to full-size bed (but is somewhat of a chore).
--Recent tinted windows on camper part.
--Steering wheel is tight, not loose. Power steering.
--Rides very smooth.
--Side entrance with dead bolt on door.
--6 cylinder, 4.3 liter engine. mpg is ??15 to ??. Really haven't determined this. Just guessing. 25 gallon fuel tank.
--Newer. never used rear tire matches tires on body.
--Newer replaced rear light assembly.
--Have front bra that makes RV look really sharp.
--Has interior furnace, 3 burner stove and refrigeration. I have not hooked up the propane, so I don't know how well heater or stove work. 3-way, 3 cu ft refrigerator runs surprisingly cold on electricity. I haven't tried the propane method.
--Has working inverter.
--2 sink combo with pump. I've never used it.
--Holds 22 gal fresh water tank. I drained it when I first got it 6 years ago, and it has not been filled since..
--Automatic transmission.
--Good amount of storage under seats.
--newer side mirrors in excellent shape.
--custom aluminum grill.
--There is a camo curtain that separates the camper from the cab. It's a tad rough but works ok. Probably would not appeal to a woman, though.
--The top vent opens and closes smoothly and does not leak. No leaks anywhere that I can see.
--There is a small dimple on the rear right hand side that is barely noticeable.
--Includes an aluminum ladder to climb up the top bunk.
--Both batteries are good
--Rear axle has recently had oil changed and gears checked out just fine.
--Very clean & non smoking since I have owned it for 6 years.
Comes with extra accessories: newer, small 12V espresso maker, large water container for drinking that fits snugly in one of the sinks, extra Durabak paint for touch-ups, 12kV to 120 converters, extra hose, study jack, used beauty rings, beauty center caps for rear rims, new air filter and oil filter, and never used bug-proof mattress cover on top bunk. Will include for free (one time offer only) new, never used camo-themed 5-gallon bucket with liners and toilet seat as door # 3 prize.
Person who buys this needs enough strength to raise/lower the top. Probably not for disabled person unless rigs some king of automatic system.
Probably most appropriate for 1-2 persons. Can sleep 3-4 in a pinch. Good option for fishermen or hunters who are tired of tent camping and who want more amenities.
