1989 Gen 1 Dodge Raider [Montero] 3.0 SWB
nevada kate
Thinking of selling my trusty 4x4 .. 3.0 5-speed manual .. 120,000 .. lots of new parts [records, receipts] .. new tires .. straight body. Roof is painted a slightly textured white [desert defense]. Took the headrests off and rear seat out [have them]. Skids. Has seat covers. Manual locking Aisin hubs. Want to know if there is any interest in this model .. will be asking $5500. Email kmwithersatgmaildotcom. Located just outside Capitol Reef NP in Utah. Good on all road conditions. Looking for a larger rig to car camp in.
J!m
Cool!!!
I bought a Daytona new in ‘89 and they had one of these in the lot... ended up with the Daytona but always liked the look of these.
Good luck with your sale!
nevada kate
Thanks Jim :) Might as well post my records of this vehicle .. have the complete set of manuals also..
Bought the Raider in 2009 .. 63,000 miles.
Oil change every 3-5000 miles
From my records:
2009:
*complete lube
*replaced hazard switch
*replaced dome light
*speedometer head cleaned and lubed
*door locks and window channels lubed
*new seat covers , steering wheel cover
*new Moog pitman and idler arms
*new power steering hose [pressure side]
*3 new wipers
*disconnected seatbelt buzzer
*replaced auto hubs to Aisin locking hubs
*new steering stabilizer
*clutch master cylinder replaced
*clutch adjusted
*3 new belts
*replaced rear bulbs
*new cap and rotor
*new plugs
2010:
*new fuel filter
*5 new tires
*5 new rims
*replaced starter
*replaced battery
2011:
*fixed window washer pump
*new KYB gas shocks
*changed trans fluid to Pennzoil Synchromesh .. both differentials and transfer case
2012:
*new master brake cylinder
*replaced front windshield
*charged AC .. R-12 freon
2013:
*replaced fuel pressure regulator
*replaced fan
*new timing belt and seals
*new water pump
*upper and lower radiator hoses
*new valve cover gaskets
*new thermostat
*new oil filler cap
*radiator flushed and fluid replaced
*new fuel filter
*new plugs and wires
*new washer pump and reservoir ..oem
*new fuel injector
*new radiator petcock
*new PCV valve
*new rubber mats
*cleaned fuel injectors
*cleaned throttle body and IAC valve
2014:
*u-joint inspection .. good
*rotors and drums turned
*new front and rear brakes
*front grease seals
*packed wheel bearings
*tires rotated
*replaced O2 sensor
*new winter wiper blades all around
2015:
*new battery
*new air filter
*replaced steering stops
*tightened steering stabilizer
*new starter
2016:
*new ICU
2018:
* 4 new Cooper AT-3 tires .. at 115,000
nevada kate
No rust at all .. spent most of it's years in the Nevada desert near Las Vegas. I bought it from an older couple who lived in Vegas all their lives.. the original owners. I will take some interior pics .. loaded with my camping gear right now.
4xCoffee
