1989 Mitsubishi Montero LWB -- $1000
Dolomiti
1989 Mitsubishi Montero LWB, 3.0L Auto
This was my second Mitsubishi Montero. I bought about 2 years ago. At that time, it ran very well and had a $3500 engine rebuild only 11,000 miles prior.
I added a set of Old Man Emu and 33x10.5s. The truck was running fine until an electrical fire started near the battery.
The previous owner had installed a remote start and alarm, which I think was the catalyst, but I am unsure. After the fire I pulled all the damaged material and began collecting replacement parts.
As far as I can tell, the fire damage is limited to some soft rubber and electrics. I have purchased a used wiring harness and much of the hoses and other parts which were damaged.
It was my intention to repair the truck but I do not have the will or time at this time. If I do not sell, I will probably keep as some frame off restoration with a diesel swap in the future when I have money to waste.
The vehicle is not running. The body is in good shape with the exception of the hood which sustained some damage in the fire.
You can e-mail me at c.scott.portis@gmail.com or 713-295-1700
High Center
Man that is a shame-
I remember drooling over your rig when I was looking for a Gen 1.
Good opportunity for someone looking to build.
Good luck.
