1989 Range Rover Classic
green
AIRBORNE
Located in Broomfield, CO
Dealer intro Great Divide Expedition County model Green with Great Divide pin striping and emblem on tail gate. 2 known issues: cruise control doesn't work and needs ac condenser for AC to work. Current on emissions and tags and drives fine, 13 MPG average.
Specs:
3.9 L V8 runs strong, unknown miles as the odometer quit
Remote mounted ignition module with Master blaster coil
Custom sliders
Custom front radius arms
Custom rear trailing arms
Custom A arm extension
Lengthened steel braided brake lines
Rovertym 5” lift springs with wedge blocks for 6.5” lift
Gulf Coast black steelies with 35x12.5x15 MTR's
Upgraded axle shafts
Pinion protection front axle
Heavy duty panhard rod
Rovertracks heavy duty tie rod and drag link
Custom rear bumper with tire carrier and highlift mount
Custom Aluminum accents in cab with custom center console.
Kenwood KDC-BT838U stereo Bluetooth, CD, USB, hands free with mic, SAT ready
WRX hood scoop
Spares that I keep on hand included:
4 Stock 3 spoke wheels with lugs and rollers
Front housing ready for Toy innards from Rovertracks
Spare new front caliper
New air filter (always buy 2 at a time)
2 spare AC compressors
At least 2 spare electrical switches for everything (windows, seats, etc…)
New water pump
Electric fan
Rear axle shafts
front hub / ball assemlies
Rear and front drive lines
Complete roof with sunroof
$3500.00 for everything mentioned above. Call Joe @ 303-507-0682
emmodg
Locked or open? What front and rear axles are you using? What's the gearing? What's the rust situation?
green
AIRBORNE
Open front and rear. stock gearing. front is a completely stock '93 RRC axle. Rear is also from the '93 and is stock with the exception of Rover Tracks Heavy duty shafts. http://www.rovertracks.com/products/axles.html one small rust spot on rear upper hatch that I took care of and sealed the window to prevent more. I beleive I remember 2 rust spots underneath around body mounts but nothing serious. None on door jams.
green
AIRBORNE
It is pushing the axles to their limit, but smart, non lead foot, 4 wheeling has been fine. Obviously being in Colorado I have pushed this thing and gotten stuck several times due to not having lockers, but they have been fine. Upgrading to a locker would mean beefing everything up as it is more stress. In its current state it does fine.
DanoWall
