1993 Land Cruiser w/ drawers
$7000, OBO Orem, UT
280k
Great running rig. I hate to sell, but goals have changed and I don't have the time/money to make it what I wanted. It is 30 year land cruiser and I am the third owner, so it does have some character. I've got all receipts from my ownership and can answer most questions.
Has a few leaks, but no roof sag, and has never overheated.
The drawers have been the greatest addition I've ever added and I'll hate losing them. They're dobinson direct drawers with expander wings and fit great. The best way to organize all of your gear you need for the trip.
The sunroof works and so do the power locks/mirros. I have the third row seats and some spare parts. A/C blows cold and the heater is unstoppable. The A/C has a small leak, but I've filled it up once every 12+ months. There is dye in it for when it needs to get refilled to find the leak.
center lock works, the light has recently gone out. You can feel it engage.
Recently had some wiring harness connectors patched up. (Karl Malone)
New fuel pump (Karl Malone)
Completely Rebuilt front axel with new (used) diff (Divinity Toyota)
New ignition module
New Ujoints (Karl Malone Toyota)
Dobinson drawer system
Dobinson 2.5" lift with medium rear springs and normal front. The rear swaybar still needs the drop plates(included), but I planned on doing that with new tie rod ends.
2.0kw starter
New front brakes and rotors
New rear brakes
New ECU from a later 80 Series (the 93' ECU is kept as a spare.
High gauge starter/grounding cables
New fuel filter
Oil change
PHH replaced
Passenger side window needs a new mount, works but gets off track easily.
Rear passenger side currently inop
Uses about 1 quart of oil between changes
Slight coolant leak, uses less than 1/2 gallon about every 10000 miles. I suspect it is coming from the expansion tank as the radiator maintains the same level.
Small fender bender that ended up with a new front bumper and passenger side panel. There was no damage to the side panel, but during the repair they decided to change it. No frame damage.
Small amount of surface rust on the underside, but nothing cancerous.
If you have questions please feel free to ask.
More pics I needed to resize
gp01
