1993 Revcon Trailblazer 4x6 Ford F350 RV Project - Portland OR *SOLD*
Avofarmer
Asking $26,000
This Revcon Trailblazer has salvage title after the refrigerator caught fire. The Interior work still needs to be completed. Alot of time, money and effort has gone into this rig. Custom Bamboo Veneered cabinetry was built for this RV that needs to be installed. It is currently being stored at the Cabinet Maker's shop and he will make arrangements with the buyer to finish out the interior.
PM me for more details and to discuss the rig too much to list here.
You are looking at a rare and hard to find 1993 REVCON Trailblazer 4x6, Class C Motor home with 41k original miles VIN # 2FTJW36G3PCA41718.
Revcon built these on a Ford F-350 Crew Cab 4x4 chassis and added an extra tag axle making it a 4x6
I have towed a three place horse trailer, with two horses in it, and a 20ft cuddy cab boat without any problems. Also I got stuck in deep sand with a trailer and the winch pulled me out and saved the day.
Mechanically it is in good condition, especially for its age, and is reliable and strong running. It is not perfect as it is a 4x4 that is 25 years old.
Also, there was a fire that destroyed about 40% of the interior, which has been somewhat rebuilt and redone. I would say about 75% Complete.
It is painted in Matte Desert Tan with a special ceramic insulating additive mixed into the paint to reduce interior heat
http://hytechsales.com/insulating_paint_additives.html
The lower rocker panels are finished in Black Bed Liner
I take very good care of my stuff and have done all maintenance as needed or sooner including oil changes. You are welcome and encouraged to come and check it out personally in SE Portland.
Additional adds and upgrades non stock:
Banks Power Pack which performs very well
Backup camera with monitor
Warn 9k winch
Dual roof mounted solar panels
Roof mounted TV satellite dish and antenna
Class V 10k lb receiver towing hitch
Dual roof air conditioners instead of only one
Upgraded 6kw Onan Generator
Additional water tankage
Cab and Chassis:
Ford F-350 4x4 Crew Cab XLT
Electronic 4-speed automatic transmission
460ci, 7.5L engine with Banks Power Pack
Limited slip axle
Quad captain chairs with armrests
Cruise Control
Ice Cold Air conditioning
AM/FM Stereo
Power Points
Power Door locks
Power Windows
Power Steering
Tag axle with air bag suspension
Tow Package with controller
Hydro brake boost system for extra braking safety
6061T6 aluminum on 24-inch centers
All joints continuous welded
Outer skin aircraft aluminum 6061T6 (.050 thick)
Coach:
Sleeps 5-6
Privacy curtains close off rear bedroom and upper over cab queen bed area
2 dinettes both of which converts to beds
Rear bedroom vanity with sink medicine chest/mirror
Two-burner stove gas stove
2 Door 6-cu. ft. automatic refrigerator/freezer w/ three-way hookup AC/DC/LPG
Convection microwave oven
Wet Bath with full stand up shower
32,000 BTU ducted furnace
2 roof fans -multi speed
Commode with step flush
2 holding tanks (80 gallons)
2 propane tanks
Sink and counter located in bedroom for dual use
Hardwood Cabinets
Comfort controls for heat and air conditioning
TV antenna hookup and roof satellite dish and antenna
Freshwater, 35 gallons
Automatic self-priming water pump
Automatic 6 gallon water heater
City water hookup
Electrical:
45-AMP converter & 12V/110V power dist center
Dual 13,500 BTU low-profile roof-mount air conditioner
monitoring panel (fresh water, waste water, propane gas, battery monitor)
30-AMP shoreline (20 ft.)
Battery boost system for engine starting backup
EXTERIOR:
Aluminum 6061T6 aircraft outer skin
Seven 35 x 125R 17” BF GOODRICH All TERRAIN TIRES
Six 17” x 11” modular aluminum wheels
Dual step bars
Off road light bar
Insulated pipes and storage
Cold weather insulation package
Locking Outside storage
Corrosion-resistant aluminum ladder
10,000 lb. capacity trailer hitch
two-level entry steps
Entry light and porch light
Dual 20 gallon LPG tank
Specifications:
Length Overall: 30 feet
Width Overall: 96 inches
Interior width: 92"
Interior Height: 77"
Exterior height: 10 feet, 6 inches
Payload: 2,480 pounds
R-20 plus insulation
Engine: 460ci, 7.5L Gas Engine
Weight Ratings
GCWR: 19,000 pounds
GVWR: 14,500 pounds
GAWR Front: 5,000 pounds
GAWR Rear: 6,250 pounds
GAWR Tag: 7,000 pound
Here is a link to pictures in its current state:
https://photos.app.goo.gl/KcSTVTthW0jqisGP2
  • TrailBlazer.pdf
  • 93 Revcon-Ford MH ACV [a].pdf
winnrider
