1994 Iveco/WS Overland Adventure Vehicle w/ Fully Converted Habitat $195kUSD/$270kCDN
Dallas Chadney
Professionally designed and built!
Features the Topi floor plan and is built on an Iveco/WS. The 4x4 chassis is off-road ready with a Warn winch and true Military tires! This truck can go anywhere your heart desires.
You'll access the camper via our signature drop down 4.5'x7.5' patio deck with pullout steps. Upon entry into the living habitat, you step into the origami wet bath, the folding door gives ultimate privacy while also providing an optional view while you do your business! The Topi comfortably seats 4 in the dinette featuring a large pullout table.
The linear kitchen was designed for two people to work together during meal prep, NO feeling of being squished or single file walking here. The habitat offers sleeping for 4 adventurers, via our hidden folding queen sized bed and convertible couch! The Topi has 77 square feet of living space with tons of storage for all your seasonal gear. While the interior is spacious and features a ton of storage, we didn't forget about the exterior! The exterior deck extends the interior living space which enables you to enjoy those beautiful sunrises and sunsets off the ground!
Below is a list of all the high quality components we've integrated into Topi:
CHASSIS:
1994 Western Star LSVW or Iveco VM90
60,000km. / 37,282 mi.
Single cab
4-wheel drive
126 in. wheelbase
9.00R16 Michelin XZL Military Tires
2.5 liter turbo diesel, 4 cylinder, 115 horsepower
60 liter fuel tank plus 2 - 20 liters portable fuel canisters. 800km range.
Truck is 24 volt electrical system.
Killmat sound dampening matting installed on interior of cab.
EXTERIOR:
Features composite fiberglass reinforced polymer skins with rigid insulation panels with fiberglass extruded corners providing superior durability, thermal transfer free and airtight properties
A custom aluminum torsion-free subframe and rear fold-down deck 7'-0" wide x 4'-6" long with self-leveling stairs.
Custom exterior tool box on driver side.
Custom split grey water and recirculating shower water tank on passenger side.
Arctic Tern door. Dual pane acrylic windows with integrated bug screen and black-out blinds.
Spare tire
MaxxTrax recovery boards
Smitty Built winch (not installed but can install or will sell for purchaser to install)
12 volt arb air compressor (not installed but can install or will sell for purchaser to install)
Custom aluminum roof rack.
Custom aluminum front tool boxes. One houses the truck batteries, one houses the hydronic heater. Additional storage in both tool boxes.
INTERIOR:
Sleeps up to 4
The habitat direct current electrical system is 12 volt. DC/DC converter used to convert 24Volt/12Volt power between truck and habitat.
Large custom pullout , folding dinette/work station countertop
Habitat size is 11'-6" ft. long x 7'-4" wide x 7 ft. high
Victron solar system with 3000watt inverter
GX touchscreen
4 - 195watt (780 watt total) monocrystalline solar panel power with 4 - 100 amp hour Pylon-Tech heated lithium iron batteries
Alternator charging while driving
30 amp shore power receptacle for charging while parked
Eberspacher (Esper) Airtronic heater
Eberspacher (Esper) Hydronic truck engine heater and on demand hot water combo heater
2 - MaxxAir 6500 9 speed fan
107 liters/29 gallons fresh water tank (inside habitat) and 50 litres/13 gallons grey tank .
Dedicated tank for the recirculating shower (30 liters/10 gallons)
Wet bath with recirculating shower.
Recirculating shower - 5 stage filtration system and UV. Endless hot water showers using a water to water plate heat exchanger inline with hydronic heater. Hydronic heater also used to heat the truck engine in cold weather.
Compoost toilet with bottle for liquids.
Inline uv filter for clean drinking water from streams.
130L Isotherm Cruise stainless steel fridge/freezer
1500 watt 2-burner induction cooktop
Large single basin kitchen sink with pulldown faucet
Corian countertops
Murphy RV size queen bed (58 in. x 78 in.) with Froli suspension system for comfort and air flow.
Modern inspired interior design and finishes
Ennis Fabric covered seating custom made
Ample storage and closet space
Dimmable LED lighting system
120 Volt and 12 volt USB Outlets
3.3 gallon per minute Seaflo water pump with accumulator.
sunnyaz
