1994 Land Rover Discovery 300tdi/R380
Mtanzania
First off I apologize that this is my first post....long time lurker but have not taken the time to register as I'm a member of so many other forums (defender source, discoweb, landroversonly, etc)
This vehicle is located in KC, MO
I was originally asking 11,500 but have lowered the price to $9500 cash...
It is currently for sale on defendersource and there have been many questions asked on that forum. Below is a link to that thread
20131203_123841.jpg20131203_123859.jpg20131203_123935.jpg20131203_123828.jpg20131202_150945.jpg20131202_150904.jpg
http://www.defendersource.com/forum/showthread.php?t=50033
I am selling my Coniston green 1994 D1 with a 300TDI/R380. It was a factory 5 speed so the swap is very natural looking. It is the base model with no sunroof and has cloth/manual seats. The vehicle has had front seat covers installed as long as I know so the seats are in great shape. Below I have listed all the work performed within about the last 2 years/5,000 miles. Currently the electric door locks are not working. They were working until the install of the A/C at which time something occurred...I would assume somebody with some sort of electrical knowledge could easily fix this. I’m just completely retarded with regard to wiring. The alarm still works if the front driver's door is locked, just doesn't activate the other door locks. Everything else works properly...factory radio/tape player, all door handles are adjusted properly, etc. Transmission and Transfer case are excellent.
Detailed Photo's here
http://s1245.photobucket.com/user/Mt...?sort=2&page=2
The vehicle was converted to diesel in October/November 2012 with a kit purchased from a member on discoweb. Below is a link to the ad for information on the kit. It included the engine, transmission, transfer case, radiator/intercooler, fuel filter assembly, etc... Since install it has performed admirably and was installed professionally by a mechanic friend of mine who is also a discoweb member. He has graciously offered to answer questions so if you would like to speak with him, let me know and I’ll get you in contact with him. He was also the previous owner of this vehicle and performed much of the work. At the time the diesel was installed, it received a new timing belt kit, front and rear crank seals, new water pump (P gasket has also been done), couple of new idler pulleys, new engine mounts welded in, new clutch (entire kit with throw out bearing), flywheel was machined, new fuel filter, new fuel injector crush washers. This vehicle was built with the intent of keeping it so everything has been done as well as possible. The engine gives a slight puff of smoke on start up if it has been sitting for a week or so but none after that. Always starts right up without any issues. Glow plugs and everything work properly.
Besides the diesel swap, the vehicle has the following, again, less than 2 years old with probably less than 5K miles
New OME HD springs and shocks, including steering dampener
Terrafirma corrected radius arms (purchased on discoweb, see link below for information)
New adjustable panhard rod
New ARB winch bumper
New Magnaflow stainless exhaust system
Replaced rear Differential with one from a RRC in order to get rid of the rotoflex found on the Discovery
New Radiator (in August 2013)
Proper A/C compressor, new condenser, etc...works great
New Silicone intercooler hoses
Amsoil fluids THROUGHOUT (transmission, engine, diff’s, etc)
Replaced the dash with a near perfect one with no curl/damage
New headliner
Good Sport King All terrain tires (stock size)
Hella 500’s (hooked up and working)
New ladder to access roof rack
Installed hydraulic rear step
Quarter panels were trimmed slightly in order to run 265’s
Safety Devices roof rack with 4 PIA lights (Not currently hooked up) and new factory mounting hardware-will also include a rear facing light and a new mount that can be easily modified to hold a tire securely on the roof rack if wanted (has spots that need to be refinished...just never got around to it)
D2 style cup holders
NEEDS:
The rubber around the back windows is cracked--should be replaced eventually.
There is a crack in the windshield...I have a good one in my parts car but not sure how to remove/replace.
Has some rust...I have included pictures. I have performed some repairs on both the front floorboards, both rear wheel wells, and the rear load space. All repairs were completed using an acid etch, POR 15, new sheet metal if needed, high strength epoxy and rivets, caulk like seam filler to seal the repaired area, and new rubberized undercoating. All products were purchased from a professional body shop and used according to their recommendations.
http://discoweb.org/forums/showthrea...e+disco+300tdi
http://discoweb.org/forums/showthrea...ht=radius+arms
If sold for at or near my asking price, I can include a ton of extras...
Please PM for more information or if you wish to speak to the mechanic who did the install
dhuss
