1994 Montero SR
newworld2004
I am looking at 1994 Montero SR with 175K on it, no history record, however current owner saying he bought from dealer 7 years ago, paint fading on hood, and front seat needs to be covered. no rust or leak, asking price is 2K, been on sale for quit a while atleast 2 months, what you guys think ? I am assuming it needs timing belt and water pump and all fluid changed.
I am going to test drive it this week , base on what is needs I am going to offer him 1K.
Merry Christmas to all.
zukrider
merry christmas to you. being a 94, make sure its a true SR. rear locker switch is next to cig outlet near x-case shifter. will also have a sunroof and leather. i say this because i have owned 2 94 SR's that only had the flares and larger v6, but were LS trimmed with no locker. i purchased mine at 198,xxx and have had no issues. but it was well cared for. i paid way to much for it too!
if well maintained its worth $2k. but starting with 1000 is a game plan. put up some pics after you drive it.
while test driving, engage the t-case. the front wheels will be blinking on the dash until the actuator actuates the front diff. if it doesnt actuate, its not a huge issue, as most people never engage them. but it could be an issue. either way, its a pricing item. the side view mirrors are likely flapping while driving. tighten a screw and there usually better. its worth it to have a shop lift it up for you. inspected all the front coolers and there associated rubber lines. all of mine are starting to leak. the power steering pump to pressure line is a common leak. ;ook for oil on the top of the alternator, will tell you if the steering and/or cam seals are leaking.
during the drive, use the trans switch on the center console, rearward of the shifter. front position is POWER. this will cause the trans shift points to be higher for towing and steep grades. you will absolutely notice a difference. if not, an issue is possible. the rear position id HOLD. this locks the trans in 2nd gear for icy take off situations. you will notice a sluggish start from a stop sign, if not, an issue exists.
good luck and happy new year!
newworld2004
thx, for info, it is definetly SR. I test drove it yesterday, it runs fine and 4x4 seems to work, I pushed rear locker bottom , howver I am not sure wahtI have to see on dash board. Ower cliam he never used 4x4 or r/r either, I believed him, interior is in really bad shape, both front seat was covered, leather on both seat and arm rest cracked. he also mentioned smoked a little during start up , but smoke goes away after warmup, while car was running I didn't see any smoke from tail pipe. I know it needs immediate timining belt since he never changed it for the last 7 years he owned it. exterior is ok, paint is fading in some area ( hood) . I offer him 1000 he didn't take it.
on side questions what is main difference between 1992 LS and 94 RS?
thx
