1994 Toyota Series 80 Land Cruiser & 2012 Adventure Off Road Trailer
RyanKM
1994 Toyota Series 80 Land Cruiser & 2012 Adventure Off Road Trailer, Professionally Modified for Overland Adventure
Morehead City North Carolina
Professionally built 6.0 Liter 390 HP LQ9 engine with LS 4l65e transmission package assembled by Turn Key in Oceanside CA, built from all new factory components. Meticulously installed by two of the best custom Series 80 builders on the East Coast. All break in and build up procedures were followed to the letter for this installation. New engine and transmission were installed in January/February 2014, photo documented and saved on a goggle drive, install mileage was at 188,800 and current mileage is at 248,023 with an average of 10,000 miles a year going on the vehicle to date. All install subcomponents (mounts, harnesses etc.) were sourced new or custom fabricated new, no used or recycled parts were utilized in the build. Vehicle has power to spare and travels at highway speed, has pulled the trailer up and over mountains in western NC, northern NH and the Rockies over and into WY/MT. Safari Snorkel has been fitted and interfaced into the engine bay.
The original fuel pump was replaced in March of 2016 and a custom radiator was installed in May 2016 to enhance cooling of the engine and an additional dual electric fan assembly with aluminum shroud was added as well. A Front Runner Auxiliary Fuel Tank is included in this Land Cruiser, the Aux Tank adds a 37.4 gallon capability to the existing 19.8 gallon stock tank. The pump for the Front Runner system was an unusual foreign component so it was replaced with a stock Ford pump used in the F150 series of vehicles. Integrated dual fuel neck has been installed so that all refilling of the gas tanks can be done from the same position. Fuel history in this vehicle is that it has always been 89 octane or better and treated with Lucas Fuel Treatment and on occasion Lucas 104 Boost. To increase electric durability a dual battery system was added to the truck and features a bridge switch for combining start power should it be needed. This system also features an integrated trickle charger and battery tender with a convenient external 110 AC receptacle protected by a marine grade cover.
Interior of the truck features a custom fabricated and recently refinished roll cage. Rear seats have been removed and replaced with a custom fabricated, padded deck that levels the floor and has storage underneath it. The deck is a real advantage if you have dogs or larger items that you want to secure inside the truck and not on top of it. In the back section of the truck there are two full size locking ARB Draws and one ARB Slider Tray that features storage underneath for tools and long items. The top of the slider is perfect for coolers, fridge/freezer (12V marine socket is in back wall near slider) or as a handy table when you stop for a break. A Wagon Gear Tailgate Storage Box has been installed and does feature a lock, additionally both rear side sliding windows have been replaced with Wagon Gear Fold Up Series 70 style glass making convenient access to the back when the tailgate is secured, these windows also lock. A recently inspected and hydro’d 15 pound PowerTank with Mount, air-line and gauge/chock is included with the truck. Interior lights have been replaced with low draw LED modules.
Externally the Land Cruiser has rock sliders, side steps and an ARB full length roof rack a large ARB rear bumper features dual spare tire carriers. The front ARB bumper has a Warn M12000 Endurance winch with 100’ Master Pull XD 3/8” Superline terminating in a safety hook, this winch features an integrated cooling fan for long pulls. Two Lightforce 240 Blitz 100 watt driving lights with covers are mounted on the roof rack, two Lightforce 170 75 watt driving lights with covers and filters are mounted on the grill bull bar and an additional Lightforce 140 is mounted on the driver’s side of the roof rack a final Rigid Side-Shooter flood light is mounted on a swivel post on the rear spare tire rack. All switching, wiring and harnesses have been marine hardened to resist water penetration and corrosion.
Other features include a Hi-Lift X-treme 60” roof rack mounted jack, custom fabricated and installed protective skid plate. Suspension is OME for heavy duty transportation trucks and also has a steering stabilizer. All 6 tires on the Cruiser are currently Cooper Discovery S/T Maxx, LT255/85R16 on the highest load bearing rated Mickey Thompson 16” rims available. These tires are all rotated regularly (all 6) and are still quite new with plenty of rubber. Internal load security points are positioned throughout the rear compartment of the truck including Mac’s Custom Tie Down VersaTrac system with several single stud tie down ring attachments. The driver’s seat is a Mastercraft Baja RS and will accept a safety harness (not included). Hood was recently replaced and modified to provide better ventilation of the engine compartment, finished in a non-reflective black to minimize glare when utilizing the roof racked mounted driving lights.
Externally mounted to the passenger side of the roof rack is a complete Foxwing 270 degree sun shade awning with all necessary support poles and extra panel that can be used to increase the shade foot print or work as a privacy wall.
All significant rebuilds and repairs are thoroughly documented in the included log book, this details dates and replacement actions too include things like radiator maintenance, bearing rebuilds etc.. Many other additional extras, features and redundant functions make this an extremely durable, reliable vehicle that gives a plenty of power and a smooth ride.
Known problems:
• Ongoing surface rust prevention is required & has been constantly performed, particularly the roof rack, vehicle is kept under a roof (Pole Barn)
• Sunroof has been sealed with caulk to prevent leakage
• Slow leak exists somewhere within the AC system and needs to be found, entire AC system is all new components with no part older than 12 months
• Stereo needs to be replaced, the vehicle is Sirius/XM compatible with satellite antennae and receiver, speakers all seem to be working fine
• Rear hi mount LED Brake Light Bar positioned in rear hatch window will need replacement within another 12 months
• Vehicle should be repainted
Both Land Cruiser and Off Road Trailer are being sold togetheras is, nothing will be parted out. Ready for immediate drive-away or pick-up for transport. Location is Eastern (Coastal) NC, willing to work with Car Carrier Service if negotiated. Asking $29,750.00
RyanKM
Trailer
This fully suspended, air bag levelled off road trailer started out as an Adventure Trailer’s “Horizon” model in 2012. The frame, design and side boxes along with the nose box all were very sound and functional. The layout for the back access door was not and all weather stripping was found to be inadequate at preventing water penetration. The trailer was therefore modified with a 1000 pound capable custom sliding tray with two position lock fitted into the entire back compartment and the door was changed to be side opening. Industrial grade weather stripping was added to all seals on all doors, LED lighting installed in both side boxes and main compartment. All doors on this trailer can be locked.
Additional modifications include a custom fabricated roof rack that has locking storage underneath it. The top of the rack has an Eezi Awn Type III Roof Top Safari Tent with extension ladder. The height of the trailer combined with the rack allows most people to walk under the tent without having to bend down. An additional room made of hanging fabric panels around the extension ladder is supplied with the tent and is a good place to keep dogs or equipment out of the weather. This tent is lightweight coated canvas and extremely durable. Inside the tent is wall storage, a fabricated LED light solution and a custom 2 piece yacht mattress secured in a cover for extremely comfortable night’s sleep as well as plenty of ventilation. The underside of the rack is a very convenient place for bedding and is sized to fit standard hard storage cases supplied by Pelican or Storm.
The trailer features its own integrated power system in the form of two deep cycle Odyssey PC 1800 RV Battery’s that are marine grade, a trickle charge system and inverter along with a volt indicator. This system can power internal/external lights on the trailer along with the integrated ARB Compressor and the 82 quart ARB Fridge Freezer located in the main compartment. External 12V marine sockets and 110V sockets for use with the inverter are located near the front of the trailer. Both batteries were replaced brand new in June 2019 and have plenty of charge volume left on them. A 7 plug socket cord for the trailer also allows charging from the truck’s electric system when travelling. An auto-retractable reel mounted on the trailer has a 50’ extension cord in it that allows charging from a small generator or 110-120V AC socket when available. Next to this reel is asecond auto-retractable reel with 25’ of air hose terminating in an integrated ARB air compressor with reserve tank that can power impact drivers, inflate tires etc..
The trailer features independent suspension that is airbag leveled for camping on uneven ground or for adjusting ride to minimize sway in rough terrain. Drainage has been installed in critical areas should the trailer get immersed. Two Toyo M55 LT 225/16R tires on the same Mickey Thompson rims used on the truck support the trailer for great clearance off road. An articulating multi access coupler with an anti-theft interface supports towing and is rated for 6,000 pds. The trailer has an electric brake axle upgrade and is adjustable through a controller in the cab of the truck. Four crank down stabilizer feet have been installed on each corner of the trailer all professionally welded and all steel design. Key areas in the under frame of the trailer have been reinforced for protection.
Exterior flat surfaces of the trailer have been coated with Line-X and are capable of being stood on to support loading, unloading and inspection of stored equipment. Multiple Mac’s Custom Tie Down Versa Trac System rails are installed with stainless steel fasteners over the exterior of the trailer. Extra with the trailer are 4 external scepter (Jerry) can mounts and hardware currently uninstalled and also a self-contained portable 12V gasoline pumping system for taking fuel out of the cans (cans not included).
The trailer has been custom painted to match the truck with the Line-X areas staying black. All travel lights function 100%. This trailer and tent are remarkably comfortable for remote camping and travel to unsupported places.
Known Problems:
• Ongoing surface rust prevention is required & has been constantly performed, particularly the upper side (exposed) of the frame, trailer is kept under a roof (Pole Barn)
• Airbag inflate/deflate has a slow leak somewhere in the system that has to be chased down, will not affect anything under 18-24 hours but after that will need more air
• Fly wheel was replaced with an industrial rubber coated caster, extremely tough but can be harder to move on uneven terrain, may want to look at a never flat knobby style
