1995 Ford F-350 Powerstroke regular cab with 1973 fiberglass Alaskan camper $35,000 obo. Located in Driggs Idaho
Frog184
Incredible Old Body Style Ford! 125,027 miles, 1995 Regular Cab, 7.3L Powerstroke XLT with new automatic transmission. Has upgraded 2008 F-250 Superduty axles, disc brakes, and suspension. Rides like a modern truck with coil springs up front. Has power windows, and center console, very comfortable and clean. I No longer need it as I’ve downsized to a smaller rig.
  • New Transmission installed with 3yr warranty Freeway Transmissions Salt Lake City May 2024
  • New Torque Converter Installed with 3 yr warranty May 2024
  • New Alternator Installed October 2024
  • New Brake Master Cylinder October 2023
  • New Radiator, Water Pump, Upper/Lower Radiator hoses, Thermostat, Temp sensor, Fuel Pump, Fuel Heater, Glow Plugs - Sept 2022
  • Entire frame cleaned and undercoated in Sept 2022
  • Line-X bed and over bed rails, quarter panels, and fender flares
  • 4:10 axle gears
  • Manual hubs
  • Eaton True-Trac Limited Slip front and rear
  • Toyo AT3 35x12.50r17 tires
  • Custom sliders/steps
  • LED headlights
  • Fox shocks
  • 2008 Super Duty F250 Axles front and rear, Disc Brakes, and 2008 suspension – to include front coil springs and Deaver rear leafs
Includes the camper. Fully restored 1973 Fiberglass 8ft Alaskan camper, Super rare! These Fiberglass Alaskans were only made for a couple years. Has LED lights throughout, Wave propane heater, 3 burner stove. Fits the Old Body Style Ford perfect. Dinette converts to a full size bed. Hydraulic hand pump raises the roof, so no electricity is required to lift the top or provide heat with the Wave propane radiant heater. Has a drawer slide with tie downs for cooler, but would be easy to wire in an electric fridge. Rubber horse mat between camper and truck. Camper comes with Camper jacks to remove camper from truck if desired.
Frog184
I have a bunch more pictures of the engine, undercarriage, and truck interior, Just having some issues getting them loaded here. Please hit me up if interested and I'll pass them along.
RDude
Wow those both look great and well maintained! I'll be in Montana this summer, so gonna have to try to come your way and check it out. Does the tailgate close with the camper on? Pics of the cab area would be great!
Frog184
I built a small tailgate extension, about 2", so the tailgate does latch closed, just didn't have a picture of it.
Mar8coLCruiser
  • 4:10 axle gears
  • Manual hubs
  • LED headlights
  • Fox shocks
Hello, I live in the area and would love to see your rig. I have a van I need to sell but this is interesting to me. That 7.3 motor is good and solid. How can we link up to check it out. Thanks
sunnyaz
