1995 LWB Range Rover with 300TDI Engine
Brit55
It is the very desirable last year of the Range Rover Classic long wheel base body with the Discovery dashboard. This truck has been setup for expedition type travel. Mileage: Vehicle 173xxx, Engine 88xxx. Modifications include: 300TDI engine. Rebuilt auto transmission. Insulated transmission tunnel. LT230 transfer case. 3.8 Ring & pinions. Custom large capacity radiator. Full width intercooler. Steel braided oil lines. 2.5” exhaust with high-level exit. Custom snorkel. ARB locker rear axle. Truetrac LSD front axle. 2” OME HD spring lift 2” body lift. Steering guard. Front and rear differential guards. Reinforced trailing arms. Lowered rear shock mounts. Lowered bump stops. On-board air system. Custom HD rear bumper with swing-away. Custom HD front bumper with Hi-lift mounts and light guards. 130w driving lights. Custom rock sliders. Rear hatch mounted work lights. Factory low profile roof rack. CB radio. Laptop mount with 12v power. Almost new BFG A/T 265x75 tires, spare is unused. HD battery cables and terminals. Numerous cargo tie-downs. Autometer turbo boost, water temp and EGT gauges.
Pictures here: http://www.seehere.com/klatter/95rrc
The truck is currently setup for transporting dogs, with a platform installed in place of the rear seats and steel grilles on the rear windows and between the front seats. These items can easily be removed and the rear seats reinstalled.
This truck is not a mall crawler, while it has been used off-road, it has not been abused and is in good working condition with the following exceptions: Electric mirrors need a wire splice, Sunroof operates but is off the track, tie rod end boots are split. Headliner is not hanging down but needs replacement, small stone chip in the windshield. Age appropriate minor oil leaks.
Spare items included: Alternator, vacuum pump, factory workshop manuals, water pump, timing belt, fan belt, viscous coupling, auto trans shifter cable, transfer box shift lever, special tools, assorted other spares.
Five-gallon fuel can is not included in the sale.
I will deliver within the greater Los Angeles area.
$16,495 OBO Contact 626-255-3004
ChuckB
That is excellent. Wish I was in the market right now, I really like the RRC. GL with the sale.
Brit55
Thanks for the good thoughts Chuck.
I put a lot of time and effort into this truck to make it reliable for remote travel and at the same time keep it's on-road manners. I really don't want to part with it, but times change and I need something bigger. I've decided to get a full size van and convert to 4x4 for my next vehicle.
Regards,
Andy
Brit55
The 300TDI engine was used by Land Rover in several different vehicles. While you won't win any drag races with it, it does have many advantages, especially for off-road driving. It needs one electrical wire to run. It produces maximum torque at 1800RPM as opposed to 3200 for the V8. It can idle for long periods without overheating and uses almost no fuel while doing so. Range per tank of fuel is much greater, and of course, you get that cool diesel clatter sound.
Thanks..... I forgot about Land Rover using TDI in their diesel engines. All I could think of was VW for some reason.
Rangie
OK, I've got to ask and I don't mean to hijack your sale thread. I've got a mint condition '91 Rangie SWB that I've set up for expeditions. Where can I get a TDI and what was involved in the switch?
buyrovers
With a little tuning, the tdi's will flat out get down the road... Just sayin.
