1995 Mitsubishi Montero SR
Styyy
Regretfully selling myvery clean 99% rust free monty for sale. I bought it 10 months ago,did the ball joints,idler arm,pitman arm,bilstein shocks,new IAC valve and 4 new Bridgestone Revos 31X10.5X15. It runs and drives well. It needs the gas tank repaired or replaced,it leaks when the fuel is above half tank. Only other issue for me was the sunroof,its closed and dosent leak, but I couldnt get it working after removing it and cleaning and lubeing the tracks. The radio needs a code (available from the dealer) because I reset the ECM after replacing the IAC valve. Interior has a small tear on the bottom section of the drivers seat. Power windos ,doors and seat all work. The truck has the desireable winter package ,the optional locing rear diff. The 4 wd is working but the center diff and therefore the rear diff arent engaging, probably because of non use. I put a pair of frontrunner crossbars with guttermounts on and attacher a Bajha Racks Megamule basket type rack. I also added a Curtis class III hitch. Never got around to towing my trailer 4x8 for wood ,with it. Asking $2750.Located in Long Island,NY. Serious inquiries can reach me at (917)539-2180.
Jerry
Styyy
Forgot to mention the odometer ,just turned 160,000 and going solid. No smoke on startup, smooth idle.
dhuss
