1995 SR Headlight Swap
mtnblue
Got some 1998 headlight assemblies I want to put in, but I have a conundrum right from the beginning. I checked the FSM to figure out how to take the side marker lights off and it really doesn't say anything other than undo the
little screw at the top of the assembly. Took the screw out and the side marker light wouldn't budge. Where are the other screws to pull it out and how do I access them? Thanks
MrGalantguy
Mitsubishi Loyalist
There is a spring with hook in the inside apron...just unsecure that.
You will need a flathead screwdriver and maybe with tape or a rag on the tip gently pry away in the space between the headlight and corner lens. The corner lens are secured by 2 tabs to the headlight...doesn't take too much force to get them off. You may have to pry from where the lens meets the fender.
Houie
