1996 Dodge Ram 3500 4x4 Diesel & Lance Camper 12valve P-pump Compound Turbo** Sold**
roamhunt
Long time lurker first time poster. Located in Lake Forest, California.
Fully restored hot rod Ram 4×4 pickup truck and matching Lance camper. Never dynoed but somewhere around 750hp. Pre emissions and no smog needed. Dream truck built to keep forever, I just don’t use it as much as I used to after getting married, and having a kid. I built the setup to easily tow my jeep or my other dodge ram offroad truck. Everything has been replaced, rebuilt or upgraded. Used brand new Dodge OEM parts whenever possible. No expense spared on this 2 year build over $90k spent. Built to look good and be extremely reliable, about 10,000 miles on truck after build has been finished. I have lots of receipts and pictures. OEM Ford color Ruby Red (RR) so that repairs can be done at any shop. I’m sure I am missing some stuff, just ask.
161k miles
P-Pump 12 valve
Compound turbos s362sxe over s475
O ringed block with 12mm Headstuds
PDD stage 1 pushrods
60lb valve springs
Full valve job, porting, and port matching by McCrae Performance
Stainless Diesel exhaust manifold with locking hardware.
PDD 7x.009 SAC 148 injectors
PDD 055 delivery valves
All Standard pump Mods
PDD Hot Rod Lift Pump
All soft fuel lines replaced with marine grade lines
Fleece coolant bypass
New OEM Radiator
BD Diesel intercooler
PDD high pressure boots and clamps
Resealed Vacuum Pump
NV 4500
Completely gone through
Ceramic twin disc clutch
5th gear nut fix
Finned PTO cover for extra oil capacity and cooling
Gear Vendors overdrive
All interior completely gone through
New Carpet kit
Single cab storage back panel
Headliner Recovered
Tinted Windows
New OEM dash
Dual layer sound deadening
Custom stereo system with custom built in sub box
New OEM heater core and evaporator core
All A/C blend doors resealed
Spod wiring system
Fusion front bumper with 4x Rigid XL lights, 2 DOT clear and 2 DOT amber
Full custom Professional paint job with all PPG products
Carli Suspension Short arms
HD balljoints
HD “Y” style steering
Borgeson HD high flow power steering pump, Upgraded Steering box, Upgraded Steering Shaft
All brake lines hard and flex replaced with stainless
Hydroboost conversion
1995 Lance Squire 8000
Great camper, all systems gone thru and work perfectly. Tanks drained, cleaned and flushed every trip. Stripe Custom Painted to match truck. Solar panels keep up with electrical demand without a problem. Generator is only needed for A/C and Microwave. I have gone 12 days off grid without ever starting the generator or truck and never getting below 75% battery.
Upgraded Solar panels and Renogy Charge Controller
Onan LPG Generator
A/C
LPG Heater
LPG Fridge/Freezer
Microwave
LPG Water Heater
Dump Valves replaced
New Propane tanks and regulator
Dual Battery system
All lights converted to LED
Custom Comfort Mattress (Money well spent, extremely comfortable)
New Toilet
Shower
No Leaks
$45k obo for the package, will sell truck separate only after the camper has sold.
949-235-0754
sunnyaz
