1996 E250 4x4 Pop Top - $8k
Johnn_o
C List Post
Selling a FORD1996 E250 4x4 for 12k. Email if interested
THE GOOD:
V8 5.4 liter gasser
The price, this is probably the cheapest 4x4 van you will find anywhere.
40 Gallon "Baja Tank" Installed and made by Agile before they switched their focus to sprinters only
Agile RIP kit installed at Agile
Passed smog
It has a pop top
4x4 is solid. The 4x4 was serviced by Driveline and Gear in Reno - I have all the receipts.
It runs great, this thing just goes, it starts up every time and I've taken care of it with oil changes, fluids, etc. and maintenance in the 10 years I've owned it.
Recently serviced at High Tech in Truckee, all of the fluids, breaks, and comprehensive check up. I have the receipts
This thing has been driven around Truckee only for the last 4 years. So low miles since all of the work that Driveline did.
Less that 1000 miles on K02 tires
THE BAD:
The pop top leaks, and the canvas of the pop top is damaged. This is the bulk of the project, in my opinion. If you are handy you could probably figure out how to fix it and clean the canvas.
When we noticed the leak. A lot of water got into the van and the interior got wet. I would suggest sanding all of the cabinets down and refinishing OR just talking out, templating it and building new.
Steering is loose, I drove it like this for a decade, its not a safety issue the steering works fine. The previous owner was accurate when he told me, "You get used to it quickly"
Got a paint job once upon a time but its starting to show wear in places
Lights on the bumper don't work
Sliding door does not open from the outside, but does from the inside.
  • Like
Reactions: zip
Psyph
