1996 Mitsubishi Canter FG 4x4
JDMBrian
Hello! For Sale is this amazing imported Mitsubishi Canter Fire Truck from Japan with only 6000 miles!
-Chassis Code FG538D is a medium length wheel base (115”) narrow cab 4x4.
-Frame rails measure approximately 9’ past cab and fire service box measures 10’ making this a great platform to start an overland style build.
-Doka or Double Cab has Hydraulic tilt feature making engine access a breeze. Seatbelts for 6 people, drivers seat reclines and slides forward and back. Steering wheel has telescoping and tilt options.
-Engine: 4D35 4.6 litre direct injected
Naturally aspirated diesel. 140 hp at 3200 rpms, with 37” tires these cruise around 65mph very well at 2900 rpms.
-Manual locking hubs on the 2 ton front axle,push button 4x4 and High/LowTransfer case controls on the dash. 5.71 ring and pinion ratio is a good match with 37-40” tires.
-5 speed Manual Transmission shifts smoothly through all the gears.
-Fire pump is driven from a PTO output shaft but has not operated since landing stateside.
offered at $39,000
Thanks for taking a look and if there are any questions i can answer please send
JDMBrian
Posting Smaller files
JDMBrian
Heres one ive been working on:
