Mooserpete
1997 Born Free President. Ford E350 custom built by Quigley. This rig's 4" lift , Quigley 4X4 (dually in rear) platform and short overhang will safely get you into campsites no other RV can attempt to reach. It is solid and safe with a full roll-cage built into its all fiberglass body. Fully self-contained and sleeps 4 adults comfortably. It is the perfect base camp for extended backcountry explorations. V10 with only 7,700 miles on new engine. Meticulously maintained and garaged.This rig is special and has been part of so many special memories for our family. Currently located in Bozeman, Montana.
Details
-107,500 total miles. 7,658 on new engine (installed at 99,800 Miles in 2020)
-GVWR 11,500 lbs.
-4 Wheel ABS Brakes
-Wheel Base 158”
Specs
Price
Details
-GVWR 11,500 lbs.
-4 Wheel ABS Brakes
-Wheel Base 158”
Specs
- 2 Tandem 6V GP Heavy Duty Deep Cycle AGM Intimidator house batteries Installed 2017
- WFCO Power Converter (WF-9865)
- 12V roof exhaust 3 spd w/ auto shut off and reversible direction MaxxAir Vent Fans
- Norcold 900 Series LP Refrigerator
- Patio Awning A&E System by Dometic
- 4000 Watt Onon RV Genset Propane Generator Model 4BGEFA26101M
- Cal-Mark RV Cover
- Back-up Camera
- Upgraded Dash Radio/DVD/Bluetooth console - Pioneer AVH - 4100NEX
- Black and Decker Toaster Oven
- Panasonic Convection Microwave
- Aqua Magic Fresh Water Flush Toilet
- Outside Shower
- 13,500 BTU DuoTherm roof mounted air conditioner - 600 Series PENGUIN
- Shurflo Whisper King Water Pump Model 2093
- Kwikee Electric Steps for back door
- Suburban LP furnace
- Atwood 6 gallon LP hot water heater
- Bike rack for front (2-4 bikes)
- Lots more extras
- Fuel - 35 gas
- LP - 23 gal
- Fresh Water - 35 Gal
- Grey Water - 32 Gal
- Black Water - 13 Gal
- Water heater - 6 gal
- 104,000 Oil + Filter Change
- 98,765 miles - Tires Rotated, Alignment, Drain/service/recharge AC System, 100,000 mile service, replaced fuel filter + spark plugs, Oil + filter change, Lube all chassis, locks, hinges, condition weather stripping, replaced air filter, Onan Generator Service - oil + filter + air filter changed
- 89,836 miles - Installed New House Batteries
- 83,260 miles - Quigley Service - New rear wheel cylinders, new front sway bar bushing, changed rear differential fluid, changed transfer case fluid
Price
- $38,000. Currently located in Bozeman, MT. This rig is one-of-a-kind, and is so solid and so nice. Feel free to reach out for more info. Please reach out with questions or to learn more.
