1997 Land Rover Defender 110 3 door Left Hand Drive SOLD
speedpin
I purchased it from enthusiast that moved from the Netherlands back to the US and brought the 110 with him. Have all paperwork etc.
300tdi turbo diesel, clean, tidy, and serviced regularly, EGR delete, new downpipe
Revotech electric fan and controller (original fan and fan clutch will be provided)
Silicone engine hose kit and most other rubber lines
New radiator and intercooler
New Ashcroft R380 with HD bearing upgrade less than 1K miles
New Ashcroft Transfer Case 1.4 ratio, less than 1K miles, new crossmember
New Roamerdrive overdrive unit, gives great highway driving RPMs, less than 1K miles
Axles rebuilt/serviced, bearings, seals, oil, axle shafts, HD drive flanges
Front and rear driveshafts
Extended braided brake lines
Terrafirma 2 inch lift springs and shocks
HD steering rods/linkages
HD Aluminum steering skid plate
HD Front Differential Cover
Rock sliders with step bars
Bonnet and fender top protection
Brush bumper, aux led lights
9000 Winch with synthetic line
Webasto auxiliary style diesel heater (will cook you out even in winter)
Auxiliary 6 gallon diesel tank (in line with main fuel tank)
Dual battery setup with isolator
Center console
Bluetooth stereo
Upgraded Hella headlights
Aftermarket insulated fiberglass roof (Helps greatly with noise and heat)
Rear 2 inch receiver/recovery point with backing plate
6, OEM Steel wheels (2 spares)
New 235/85 R16 tires
Mantech swing away tire carrier
Frontrunner roof rack with awning and shovel mounts
Howling Moon sun awning
2 NAS style rear jump seats with retractable belts
Adjustable cargo tie down tracks in rear
Tub cappings and interior cargo area has been color matched liner
Exterior presents well but has been driven and used as a rover, has some scratches, dings, character.
Interior is complete and tidy
Frame/crossmember extremely clean and has been coated previously by Dinitrol product (protective film/coating)
Clean Clear VA title in my name, recently passed VA inspection. The defender is tight and drives great on and off road. Reliable and not a white-knuckle experience.
Recently took it to the Virginia Mid Atlantic Rally camping/off-road trip without issue. If you are looking for a solid, well sorted, and roadworthy defender this is it.
speedpin
Pics
speedpin
More
speedpin
More
sunnyaz
