1997 LS swapped Built Jeep TJ
speedpin
Looking to sell my 1997 LS swapped TJ. About 1400 miles on build. Needs nothing, flawless on and off road.
Asking $21K obo Located in Stafford VA. Current inspection and tagged without issue. Can be classified as a classic next year, no emissions or inspections required.
More pictures here:
https://photos.app.goo.gl/d4z6kpK82yUdY7Xc9
HU6wfNeNUjFrPPsE9
Engine/Power
LS Motor swap (Bully Shop installed) includes daves motor mounts, wiring, fluids, hose, flahsing etc.
PCI wiring harness
Motor and transfer case from a 2005 Silverado 4x4
Reman transmission (includes installations and has 18 month warranty - receipt provided
Autometer Gauges - receipt provided
Art Carr Winters Shifter for 700R4 & 4L60E
Superior radiator 16" fan and shroud
Dynomax Cat-Back (97-99 Wrangler TJ) Custom y pipe and electric cutout
Sanderson blockhugger headers
Novak Conversions SK2XC Adjustable Cable Style Transfer-Case Shifter Linkage
Miscellaneous exhaust work
NP241C HD SUPER SHORT SYE
Interior
Rugged Ridge Sport Seats 13415.15
Sparco 04608BVNR Black 2" shoulder harness
Bedrug BTTJ97R BedTred Rear Cargo Liner Kit
Bedrug BTTJ97R BedTred Front Cargo Liner Kit - NC
2 of Sparco 04608BVNR Black 2" 3 Part Belt
Red eye custom cage
Rock Hard 4X4 straight across harness bar
Standard width aluminum center console for Jeep TJ or LJ with cup holders
Stereo
labor
JVC Stereo w/ 4 - 6.5" Kicker Speakers
Sound bar from ebay
SA4.50 - Memphis 4-Channel 320W RMS 640W Max Full Range Class D Amplifier
16-SA1.300 - Memphis Monoblock 300W RMS 600W Max Motorcycle Amplifier
Custom Subwoofer Box with Kicker Speakers
Wiring Harness for 2 amps
Exterior
RedRock 4x4 Trail 13 in. Short Antenna (97-06 Wrangler TJ
Genright Aluminum fenders (not including install)
Genright corner armor (steel) (not including install)
Genright rocker guards mini boat sides with shipping for all Genright parts (not including install)
Pavement Ends by Bestop 56840-35 Black Diamond Frameless Sprint Top for 1997-2006 Jeep Wrangler
Motobilt Jeep YJ, TJ, LJ front bumper - MB1069 plus powder coating for $100
Body Armor 4x4 TJ-2961Black - Steel High Clearance Base Rear Bumper for Jeep Wrangler 1987-1996 YJ and 1997-2006 TJ
Rugged Ridge 11229.01 Black Powder-Coated Gas Door Cover
Warrior Products 1561 Side Mount License Plate
Rugged Ridge 13505.04 Ultimate Black Grab Handle - Pair
Powder coated Steel Hood Latch
Smittybilt 7686 Black Entry Guard
Rugged Ridge 12419.23 Black Headlight Bezel - Pair
Poison Spyder Hood Louver
New door surrounds
Poison Spyder Hawse Lead
Replaced old mirriors with Kool Vue Manual Remote Mirrors - OEM
Factor 55 thimble
Smittybilt XRC Gen 2 winch with synthetic rope
Currie Enterprises CE-9900 Antirock Front Sway Bar Kit for Jeep TJ
UCF oil pan and transmission skid
Aluminum Savvy Gas Tank Skid 1997-2006 TJ/LJ
Five Brand new 35x12.50 17 Procomp Xtremem MT2 with simulated beadlock wheels
MeatalCloak rear swing out body mounted tire carier
Custom belly skids (engine/trans/exhaust)
Mechanical
CavFab cross over steering and High steer tie rod/drag link
Pro Comp 2" Lift Kit with MX-6 Shocks, and bump stops with labor and alignment
Daystar KJ04508BK Comfort Ride 1" Body Lift Kit
Iron Rock Adjustable Control Arm Kit (
8)
Rear Dana 44 LJ Axle, Riddler diff cover, ten factory chromo shafts, rotors, ceramic brake pads, factory locker (front), 4.88 Revolution Gear set w/Koyo Bearings, fluids, install
Dana 44 LJ Rubicon Front Axle with RCVs, new artec c gussets, clayton 3 link truss, control arm skids, new alloy usa ball joints, new hubs, alloy usa outer axle seals, new factory air locker, 1/4 diff cover, 4.88 Revolution Gear set w/Koyo Bearings and gear install
Powerstop pads and rotors
Lights
Instrument and HVAC Lights
Maxbilt MBLTT-150 Round Trail Tail LED Tail Lights
2PCS 7 Inch 75W High Beam 35W Low Beam Phillips LED Headlight with DRL For Jeep
EP 26 (5 pin flasher)
iStan814
