1998 Land Rover Discovery 1
dos531
1998 land rover Discovery 1
Camel trophy homage livery
Has been a great trail rig and never let me down. Purchased a new car so I have to thin my herd of rigs. I have maintained the mechanicals of this truck meticulously so it has been very reliable. I also have a lot of spare parts that will go with the truck. Mechanically in very good shape, everything that I have found needing attention has been addressed. Ac blows ice cold, and heater blows hot
Doesnt use coolant. It's still a land rover so it does have oil leaks, but nothing bad enough to effect levels. Idles very smooth and passes smog easily.
Issues:
Sunroofs disconnected, but dont leak
Cruise control inoperable
rear driver side door lock actuator wont unlock automatically
small exhaust leak
Mods:
Suspension:
RTE johnny joint rear control arms
RTE upper a-arm extension
RTE Rear spring dislocation cones with retaining hook
Front Old man emu 3" lift shocks
Rear Bilstein 7100 12" travel with external reservoir
Ironman 4x4 springs
1" spring spacers front and rear
5" extended brake lines
Terrafirma Heavy duty tie rod
Terrafirma Heavy duty Drag link
Terrafirma Heavy duty adjustable panhard bar
Drivetrain:
Aluminum coolant expansion tank
Roverware Weld on diff guards
TRE rear air locker
TRE compressor
Raptor 4x4 heavy duty rear axles
Terrafirma Heavy duty drive flanges
Exterior:
Safari Gard front bumper
X-bull 12000lb winch
2 x 9" led off road bumper lights
6 x 7" led off road roof lights
Rock sliders
Custom roof rack
Safari snorkel
Hood louvers
5 x Alphaequipt Command 16x8 aluminum wheels
5 x 305/70r16 Milestar Patagonia M/T
Interior:
Custom rear drawer system
Rear tailgate table
12v rear power supply for refrigerator
Ram mount rail on dash
Ultragauge obd monitor
Bluetooth head unit
kicker door speakers
Rear view camera mirror with front/rear dashcam
120a alternator
AGM battery
Maintenance items:
Within last 6k miles:
Oil changed with Shell Rotella
All fluids changed
Cooling system completely overhauled
Oem radiator rodded out
180f thermostat
Heavy duty fan clutch with chevy fan
All new hoses
All new belts
Airtex water pump
Every suspension bushing replaced
Front wheel bearings
1 new CARB approved catalytic convertor
Previous maintenance:
Rebuilt transmission
Driveshafts replaced
Carb approved catalytic converter
Spares:
Complete differential 3rd member
Alternator
VSS
IAC
Fan clutch
radiator hoses
Serpentine belt
Brake switch
Radiator
Fuel pump
Cylinder heads
Intake manifold
Rear door trim
2x wheel bearing kits
Swivel ball reseal kits
4x steel beadlock wheels
1x steel wheel
I'm sure i'm forgetting some items so I will update as I remember
$7900
Los Angeles, CA
20210424_161654.jpg20210514_114559.jpg20210514_114603.jpg20210514_114608.jpg20210514_114613.jpg20210514_114628.jpg20210514_114637.jpg20210514_114642.jpg20210514_114647.jpg20210514_114657.jpg
