1998 Mitsubishi Montero
1998 Mitsubishi Montero (GEN 2.5) Winter Edition 212k miles
Seats 7 (3 rows)
25 Gallon Gas Tank (400 mile range)
3.5L SOHC V6
SuperSelect Shift on the Fly 4wd System (2wd, AWD, 4lo, 4hi)
REAR DIFF LOCK
4 Speed Auto
Power Windows/Locks/Seats/Mirrors/Sunroof
Heated Leather Front Seats
MODS:
ADV DRIVEN DESIGN sourced Bilstein 5100s all around (5k miles ago)
ADV DRIVEN DESIGN Front Bumper
MOOG Tie rod ends (10k miles ago)
JDM Clear Corners
Land Rover Ladder
AISIN manual 4x4 hubs
5x Toyota Steelies (custom machined to fit montero center bore)
5x COOPER ST MAXX 255/85r16 60% tread
WHITE BALL TC SHIFTER MOD (* mandatory mod on gen 2.5s *)
YAKIMA RACKS
Custom Sleeping platform/gear storage YETI 45 included with purchase
MAINTENANCE: (have receipts for most all work done)
Around 150k miles:
Full timing belt (belt, water pump, cam position sensor, crank position sensor, front cam seals, UPDATED crank bolt) New Radiator, Wheel bearings
Around 175k miles: Plugs, wires, valve cover gasket, spark plug tube seals, pcv valve grommet, oil filler cap gasket, rear cam seal, thermostat, diff fluid, transfer case fluid
Recent: EGR Valve, front brakes, bunch of hoses, transmission fluid flush with Mitsu Diamond SPIII
The BAD:
AC compressor bearing seized
DUE FOR NEXT TIMING BELT JOB (60k mile interval, interference engine, and water pump just developed a leak)
Driver side rear door latch broken (have new part for it)
Rear windows and sunroof is slow (common in monteros)
ASKING $3800 obo
I will post pics soon heres a CL link in the meantime:
  • Like
Reactions: plh
xander69
