1999.5 Ford E-350 Camper van located in Salt Lake City, UT
Standoner
***Price Reduced***
For sale
7.3L Power Stroke Diesel
$65,000
For a walk around of this vehicle-
Vehicle details-
1999.5 Ford E-350
94,000 miles on motor, 30,000 on rebuilt transmission (done by John Wood automotive)
Quigley aftermarket 4x4 installed by Sports Mobile (I have the documentation for this)
The current number of seatbelts is 3.
Motor, transmission and chassis-
Hydra tuner installed by Stroker Diesel outside of Salt Lake City three months ago
Transmission rebuilt by John Wood automotive 30,000 miles ago
Custom cold air intake with Donaldson B085011 Air Filter
Airdog 2, 4G fuel pump and filtrations system
CNC Fabs fuel bowl delete block and 4 line return system
New turbo pedestal (no EBP cylinder) and non EBPV turbo exhaust
Riff Raff Diesel billet aluminum intake manifold plenums and CAC boots
Dipstick Adapter Repair Kit (Riff Raff Diesel)
8 New AD injectors 15,000 miles ago
Aero tanks 40 gallon main fuel tank
Aero tanks 40 gallon aux fuel tank (mounted in the back where the spare tire used to be)
Both 12V starter batteries are mounted on the frame rail and are about a year old
New under valve cover harness and gasket, done with injectors
New HPOP lines and fittings
HPOP long threaded plug and gasket
Agile Offroad, Fox aftermarket shocks and springs (tuned for this van)
Aftermarket leaf spring packs
GlowShift A pillar gauge cluster (fuel pressure, transmission temp turbo outlet temp)
Turbo pressure mechanical gauge
Alumines front and rear bumpers
Aluminess storage box and spare tire carrier on rear of vehicle
Warn 12,000lb winch mounted inside front bumper
Recovery points on front and rear of vehicle
Pop top-
Sleeps 2 adults and one child in the “up stairs” and 2 more adults “down stairs”
Colorado Camper Van pop top (powered with remote control)
Max Flow air vent
2 Solar panels- Eco Worthy 320W
Yakima rack with basket
Living space-
All three seats swivel 180 degrees when parked
LED 12V internal lighting throughout
Espar diesel heater with high altitude add on. (plumbed to main diesel tank)
NorCold DE-451, 12V fridge
20 gallon fresh water tank
Sink with 2 taps, one filtered one not filtered
12V pump with inline water filtration leading to small tap for drinking water
Fiamma awning with LED strip lights
External 7lb propane tank mounted to frame rail
2 propane quick connects, one inside one outside for cooking
2 burner Partner Steel propane stove with stand
Pots and pans included
Plated, cups, silverware, cutting board and other utensils included
Pioneer stereo with aftermarket speakers
Safe hidden in back bench with thumb print and key entry
Thetford porta-potti
House electric-
Perfect Switch “Power Gate Dual Rectifier” battery isolator
Magnum Energy 2012 Pure sine wave inverter/ charger with mounted remote
Blue Sky Energy 3000i solar controller/charger
210AH, 12V, AGM house battery (new in 2022) can be charged by shore (220V or 110V), alternator or solar inputs
Victron Bluetooth remote monitor for house battery
Marine grade 12V wiring and aux breaker panel
4, 120V GFI outlets
Multiple USB, 12V charging ports
Timboruski
