1999 Dodge Ram 2500 5spd Manual
surlydiesel
Sorry, this isn't specifically an expo vehicle but could be built into one. Was used to haul a slide in camper years ago.
1999 Dodge Ram 2500 with the 360 big block gas motor and a 5spd manual transmission. Club Cab, Long Bed, 4X4
102,349 miles
The interior is in very good condition. Seats are not ripped and quite comfortable. The flooring is rubber and the windows are manual. Has an aftermarket stereo with an active subscription to XM.
No inspection in the state of NJ.
Comes with a trailer brake setup and everything works as it should.
Very little rust on the cab, cab corners are intact. Has had a lot of work done in the last year:
New Brakes Front and Rear
New Radiator
Rebuilt Rear End
New Rear Spring Shackles
Rebuilt Transfer Case
Tune up - Plugs, Wires, Distributer ect.
4wd Actuator on the front axle
Fuel Tank Straps
Known Issues:
Check engine light for O2 sensor after cat, comes on and turns off. Just needs a new one.
Small amount of play in steering box
Bad AC clutch
Needs a check valve in the fuel system (longer start times)
Rust
5,000 OBO
Call, Email or Text with questions.
908-854-9898
Located outside Blairstown, NJ.
Thanks,
George
4xCoffee
