1999 fog light ?
Silverwulf
Hi Guys, I have been going around fixing some piddly little things on my new (to me) Montero.
I have a question. I have a 1999 with the little round fog lights in the bumper. How do you replace the bulb? It looks complicated to get to? I come from BMW land where it is 3 clips and the fog lamp is out and the bulb is out.
Please help.
Thanks, Chris
Mad Matt
There are a couple of screws on the back side of the fog light assembly, take them off, the back housing comes off and then you get access to the bulb. I put PIAA Ion yellow bulbs in mine and they worked brilliantly.
Silverwulf
Thanks MadMatt! I looked at my light and there are 3 screws , but they are on the bottom of the light and one of them has very little room to fit a screw driver (less than 3"). Are ther other screws I'm just not seeing?:peepwall:
Also, I am wiring up a set of Hells 700ff's. Everything is wired but the switch. I am trying to run the trigger wire from the engin bay to the cabin. I located a rubber grommet on the drivers side inner fender wall and have passed the wire through that. Now the wire is in the fender. I cant find any holes around the side of the drivers side kick pannel. I dont want to start drilling if I dont have to.
Thanks again!
