1999 Ford E-450 7.3l 50k miles Ambulance Utility body $28500
Tcali81
1999 Ford E450 Rescue Utility body Ambulance 7.3L Powerstroke with 50K miles/less than a 100 Idling hours
Serious buyer only if you know ambulance's you know it's impossible to find one with this low of miles and idle hours with maintenance records from a rust free state. Interior/exterior in near perfect condition for a 20+ year old truck.
• Purchased from Lane County Fire Dept June of this year for $16,500
• Detailed full digital maintenance records for the last 10+ years
• Clean Title/Carfax Report; Registered Oregon truck, rust free Chassis
• 5’8” standing height in 14’ long box on a 158” wheelbase 9’6” overall Height
• This Ambo conversion is 90% done you finish it and save a ton
• Designed to seat 6 legally with seatbelts.
• Kenwood DMX7706S Double Din head unit W/backup camera and 2 6x8 Kenwood speaker $500
• 6 brand new 50,000 mile M/S tires $1200
• Sinister Coolant Filtration System $170
• Scangauge 2 engine monitor for 7.3L $170
• 2 Maxxair 7500K $660
• Nomadic OVS passenger side 270 Awning $950
• Nomadic OVS Drivers side 180 Awning $750
• Custom high end Marine skylight $800
• Custom Acadia wood countertop and ceiling $750
• Waterproof vinyl flooring $150
• Fabric/thermal barrier for curtains and seats $250
• Backsplash tiles $100
• Norcold N8DCSSR 12-volt 8 cu ft refrigerator/freezer $1400
• 300AH LiFeP04 Lithium Battery $1300
• Renogy 12v 50A MPPT charge controller $300
• Renogy 4-100Watts flat solar panels $720
• 1500W inventer $600
• Heavy gauge wiring, relays, blocks, fuses etc $350
• Renogy 500A Battery Monitor $80
• Recessed ceiling/cabinet light $150
• Thetford Porta Potti 365 $165
• Furrion 7500K propane 3 burner cooktop $275
• Class A 42 Gallon fresh water Tank $130
• Surflo 42 series water pump $80
• Bosch 4 water heater $200
• Outdoor all in one propane shower $280
• Stainless Steel sink 15”x17” with brushed nickel Faucet $250
• 8” memory foam full size bed $250
• R-13 insulation throughout the box $250
• Home depot/lowes/Jerrys Receipts $2800
• Camping World/Walmart Receipts $1300
Tcali81
I'm selling mainly as a timing issue. I was supposed to do a trip from Alaska through central America and back the beginning of last year. Covid pushed it back several times. Now changing traveling platform and will not need the rig anymore. What needs to be done is all the finish hookups for solar, electrical and plumbing. Basically everything needed to finish it has already been purchased.
Delsh
Hard to see where the additional seating is located ('designed to sit 6 legally with seatbelts') - have a pic? You located in OR (where ambo was purchased), AK, or elsewhere?
Tcali81
Im in northern California ambo was purchased in OR as stated in the top of the posting. Seating is under bed it converts into 4 seater table and uses the orginal bench seating and seatbelts.
Tcali81
Also forgot to mention in the original posting I upgraded the exhaust system ($700 installed) to a 4" from the turbo back.
gp01
