1999 Ford E350 4x4 "Sportsmobile" Top 66k Miles - $26,500 - Oceanside, CA
jj2366
Ford E350 Extended with 4x4 conversion by Advanced out of Utah. Custom front and rear bumpers. Rear bumper was built to hold a tire and box. Custom leaf springs, Bilstein Shocks , changed the pinion angle and shortened the drive shaft etc. All work done by North County Spring (specializes in Econoline suspension) and Oceanside Driveline. Also had the transfer case serviced and all the bushings/ seals replaced when I installed the new driveshaft. Raptor lined with 4+ coats of liner done at an auto body shop. Sportsmobile penthouse manual top with 400 watts of solar, 105 watts of solar on the hood for a total of 505 watts of solar. 400 AH lithium battery (new) charges off the alternator and the solar and is controlled through the Renogy app. Interior has a Decked drawer system, electrical setup with 3000w Pure Sine Inverter, 400 AH lithium battery, solar / alternator charge controller, usb outlets, 6 x overhead lights, 12v air conditioner / heater, Apple CarPlay. 66,300 original miles on the 5.4L V8. Just had the oil changed. Tons of potential, this thing will go just about anywhere and looks insane going down the road. Insulated with Havelock wool and cedar siding on the walls, floor is rubber mat with kilmat underneath, ceiling is insulated with upholstered panels. I also have a water tank, pump etc. that I will let go with the van. Work is moving me and I can’t take this with me. Clean title in hand. Located in Oceanside, CA. Let me know what questions you have!
sunnyaz
