Selling my F450 4x4 ambulance, it is a 7.3 powerstroke with a zf6 6 speed transmission stock, Was not swapped in. Motor has been gone threw to help it have good power to move a 14,000 pound truck on 41” tires and keep up with traffic. Has new
Up pipe kit
Turbo rebuilt with a wicked wheel makes 17ish psi boost now and EBPV delete.
Full 4 inch straight pipe exhaust.
New water pump, old one started to leak.
Larger fuel pressure banjo bolts
Added fuel rail crossover lines
Added oil crossover line.
has a hydra tuner ran on a tow tune
I’m sure there’s more it’s just been awhile since I’ve done the upgrades and forget what all was done.
Lifted 2 3/4 inches
Bushwhacker fender flares
Military mrap aluminum wheels
Continental Mpt81 41” tires.
4.88 gears
dual steering stabilizer
Front receiver hitch
Receiver hitch mounted winch so you can move it front to back has synthetic line and wireless remote
Truck batteries are agm not plain lead acid
Box color matched raptor liner to match factory ford cab color.
slide locks on cab doors since Ford trucks are the easiest vehicle to brake into
Cab has sound deadening
Leather seats out of a excursion limited
Upgraded touchscreen radio with Bluetooth and a link so you can monitor the engine vitals on the screen.
has a pass threw to get to the back of the box.
8 gang switch panel, only 2 in use. 1 to charge house batteries as you drive and 1 to turn on the rear camera without having to put truck in reverse.
Box still has the original cabinets and floor inside.
Original roof replaced with pine tongue and groove
added a bed system/ couch that’s 3 ft wide and 6’4 long and sides out all the way across the box to fit 2 people.
Has a full length table too so on bad weather days you can fit 6 people around it or just a good work station.
2 100 amp hour lifepo4 house batteries
Dc to dc charge to charge while you drive.
265 watt solar panel mounted on roof
60amp mppt solar charger.
2000w pure sine wave inverter.
12 volt 5 switch panel with 12 volt plug chargers and battery volt meter.
Propane instant hot water heater
I only use 12 gal fresh water but can easily fit 24 gallons the way it’s set up.
Full size sink
Deep freeze chest with a fridge thermostat, hardly ever has to kick on. Way better than the 12 volt electric cooler.
12volt diesel heater plumbed directly to the fuel tank.
insulated window blackouts.
I am traveling full time out of the truck right now and I Absolutely love it. With the 6 speed you can use the granny low gear and just crawl off-road over anything with no throttle then jump on the highway and run smooth down the highway at 75mph with one hand on the wheel. Truck gets up and goes fast. No crawling up on ramps and stuck in the slow lane, you can easily keep up with the flow of traffic and be passing people on the highway. If your on flat ground and no head wind your get high 13’s mpg and with a good head wind I get 11’s. Which is amazing for the weight and 41 inch tires.
has 227,095 miles, will go up as I still drive it.
no oil leaks, doesn’t burn oil, no trans leaks.
I guess doesn’t leak or burn any fluids.
will need 2 new tires soon
Rear door latch
And I guess if you want the cozy instagram apartment interior it could use some painting and trim. This truck was built to be functional. It will do serious off-roading anywhere you want to go. When 4x4 sprinters have to stop because of a little ditch this truck hasn’t even started to work hard yet. You can get into serious backcountry/ go down utv trails drag tree branches down the box and it’s fine since it’s solid aluminum. Can fit mountains bikes or a dirtbike up into the box for safe keeping and still sleep inside. I have more pictures but it only lets you upload so many. Price $50,000 Any questions feel free to text or call (816) 724-7093 or ldcreach@gmail.com
Up pipe kit
Lifted 2 3/4 inches
4.88 gears
Full size sink
Rear door latch
