1999 Jeep Cherokee Classic.
Bbasso
Expedition goofball
Sold.
thank you.
ALL CASH IN HAND OFFERS WILL BE CONSIDERED, What are you offering? But read first ;)
I'm selling my 1999 Jeep Cherokee Classic.
It has 160,000 miles and still being used everyday so mileage will increase.
No accidents, but does have a few digs n dents, nothing horrible.
NO RUST!. Born and lived South Carolina/ Georgia, maybe once or twice has it seen dirt, never snow.
Clean title. I'm the third owner. Build date is 02/99.
Has the 4.0 liter Inline 6 cylinder motor (242 CID) 190 hp/225 lb·ft with the Aisin-Warner AW-4 4-speed automatic transmission. Both are all in original condition, the head is the 0630 head, no worries about it failing.
Has the New Process NP231 "Command-Trac", part-time only, 2.72:1 ratio with low range transfer case.
Front axle is a Dana 30, High Pinion, Reverse Cut, 297x/760 universal joint, 27-spline axle shafts the rear is a Chrysler 8.25", c-clip, non-ABS, 29-spline axle shafts.
New radiator, OE radiator cap, hoses, 195 deg thermostat, water pump, HD fan clutch, belts, valve cover gasket, oil filter adapter O rings, New fluids in everything but the front axle.
Front brake pads and resurfaced the rotors recently, Air filter, A/C system was checked over and 100% passed with cold air. Heater works great.
Cooling system works great, operation temps are between 195 and 200 max of 206 deg.
Power windows, power door locks, power mirrors, cruise control, overhead console w/ computer, cloth seats and Very comfortable!
Included in the sale will be many installed items:
Weathertech window rain gaurds.
Hella 700FF driving lights with Hella's upgraded 100 watt bulb in each.
Additional OE fog light switch with a relay for the Hella driving lights.
pair of all metal yellow fog lights, inexpensive but work great.
Some interior LED bulbs and some exterior LED bulbs.
750 watt power inverter under passenger front seat.
Cobra 19 CB radio and magnet mount CB antenna on the roof.
Has rear tow receiver, some recovery gear.
Has front OE tow hooks.
Putco wiring harness for headlights.
I bought n installed factory Infinity tweeters for the front doors.
All five tires have less then 5,000 on them, Matching full size spare and matching full size alloy wheel!
Tires are BF Goodrich All Terrains KO, 31 X 10.5 on 15 inch factory alloy wheels, balanced and no vibrations.
AVG Miles Per gallon are 15 city /20 Highway
Scanguage II, possibly included in sale... If I like your offer.
A full 3 inch BDS suspension lift kit.
No spacers, no blocks. Done right with the right equipment installed by a professional shop in Charlotte, NC. Receipt in hand.
New BDS Coils in the front, New BDS full leaf springs in the rear.
New BDS shocks in each corner.
New BDS lower front control arms.
New BDS steering stabilizer.
Most of the hardware is new for the suspension lift.
Removed rear sway bar.
Front sway bay is stock with Zone's quick disconnects.
Moog bushings for the front sway bar.
Wheel alignment was done 3 months ago.
48 inch HiLift jack, under rear seat.
Interior condition is 9.5 of 10.
Exterior condition is 8 of 10.
Running condition is 9.9 of 10.
Nothing is broken.
Everything works great.
Turn the key and go, needs nothing.
Asking for your dead serious cash in hand offer. I would like to get $6500.00
Contact: Bbasso@yahoo.com
please send me an email and we'll discuss.
I hope the pictures show the condition, please ask for more pictures if you want.
On to the Pictures!
The day I bought it
Video of the day I bought it
Bbasso
Current video taken on 02/02/13
Bbasso
Radio
Under the hood
Underside of rear
front suspension
rear suspension
fog light switch and CB
additonal lighting and tow hooks
Sitting outside
the 630 head
inside rear while changing the fluid
cleaned with new Orings
Hella driving lights @300yrds
on the beach for kayak fishing in TX
Loaded up from SC to NV
http://i50.tinypic.com/25hk5yu.jpg
http://i45.tinypic.com/x21bus.jpg
http://i45.tinypic.com/dp8vwk.jpg
MTSN
No offense but I think the price is quite high for the miles. Nice looking truck but at $8k you're competing with a lot of other vehicles on the market that are pretty built up.
MCObray
I really like your XJ. You and I both shared many similar ideas when putting our XJs together. Hold out for the right buyer... mine had 113K and ended up fetching near what you are asking. GLWS!
flipstick
