1999 Land Rover DII Lots of Upgrades
nickb857
Listing my modified Land Rover Discovery 2. I got it in 2003 with 25,000 miles. Currently it has 125500 miles. Over the course of the years it has been tastefully modified and re-done a couple times. I try to do most of the work myself but when it was at a shop it was at Holland's Garage in CT or Kensington Motor Cars in Las Vegas.
Being that it was in New England there are two rust spots in the front passenger and driver foot wells. I was careful to clean, wire wheel and repaint the rear frame frequently, so that area is pretty good. The tank should probably be dropped to get that area cleaned up as well.
It drives nicely and will cruise at 80 all day long.
Currently it is located in Redondo Beach, CA
As it sits it has the following:
Engine/Drivetrain
4.6 with Crower Stage 2 Cam From D&D
Alisport Radiator
Aluminum Overflow Tank
Mantec Snorkel
TF Axle Breather Kit Routed to snorkel
NRP Exhaust
Tom Woods Front Drive Shaft
DI Rear Drive Shaft
04 CDL Linkage
Transfer Case has been resealed, but looks like it might be due for another.
Transmision has been serviced with new seals.
I got front and rear axle housings from a DII in Vegas and rebuilt them with the following:
Front: Ashcroft axles and CVs, 4.11 Gears, ARB Air Locker, Axle Truss, New ball joints
Rear: GBR (I think) Axles, 4.11 Gears, ARB Air Locker
ARB Twin Compressor and Tank in rear cubby box
Lockers and Compressor wired to factory 3 switch panel where ashtray goes
Wheels/Tires
18" LR3 Wheels
275/65 Toyo MTs
Bumpers/Skid Plates
RTE Front Bumper
Warn 9.5t Winch with Viking Synthetic Rope and Locking Swivel Shackle
Hella 4000 HID Compact Lights
Mesh Grill made by me.
RTE Rock Slider
GDE Rear Bumper
TF Transmission Skid
TF Front and Rear Diff Guards
Mark Oliveres Rear Pinion Guard
RTE Tank Skid
Mantec Rear Window Guards
Front Suspension
Currie AntiRock Front Sway Bar
Front OME medium springs
TF Dislocation Cones
RTE Shock Towers
10" RR Fox Shocks
RTE 3* Radius Arms
RTE Adjustable Panhard
Terrafirma Steering Links
Rear Suspension
Rear OME Medium Springs
TF Rear Dislocation Cones
7100 RR 12" Travel Short Body Shocks
RTE 3* Trailing Arms
RTE Watts Linkage
Misc/ Interior
Odyssey 31m PC2150 Battery
Hood Louvers
Full black interior from 2004 DII
Lowrance HDS 5 GPS in overhead where map light goes.
Lowrance external Baja GPS Puck mounted onto snorkel top
Spare Parts:
Heim Joint Steeling kit with 1.5" DOM tubing
Superwinch Husky 8 with Bow Motor 1
OME Medium Rear Springs
Has the 3 amigo ABS lights, and the SRS light is on due the driver seat belt pre-tensionser.
Price: $10,000
Thanks,
Nick
quigleyth
