Go4Lo
As anticipated after adding the ARB style front bumper and winch to my '02 Tundra the front end has dropped about an 1". I've done everything I can to lighten up the front including synthetic rope, aluminum fairlead, and relocating the solenoid box under the hood. The next step is going to be to address the front suspension to compensate for the added weight.
My current set up is comprised of Bilstein 5100 shocks set at the top notch with my stock Tundra TRD coils. My goal is to regain the lost lift for 2.5" total lift. Below are few idea's I'm kicking around and I could really use some input before spending any more $$.
One - Add a set of 3/8" top plate spacers to the current set up. My fear is this will be too much preload on the springs and make the ride even stiffer?
Two - Buy a set of OME 886 coils and drop the Bilsteins to the bottom notch (stock height). From my research the OME coils are just over 15" tall with a spring rate of 660lbs. There is a LOT info on the forums from guys running the OME coils on the adjustable Bilsteins with success, but these are all on Tacoma's, 4Runners, FJs, and NOT Tundra's. This idea came from the fact that Slee sales a 1st Gen Tundra lift kit with the 01-04 Tacoma OME Struts matched to the 885 coils which are for 05+Tacoma's. In theroy IF one could run this set up with the 885s why wouldn't the 886s work?
Three - Aftermarket Coilovers, DR/Icon, SAWs, Toytec. These all come with 650lb springs, which "should" be able to handle the weight. The downside of these is of course cost and possibly harsher ride and continual maintenance.
Any help would be greatly appreciated. :smiley_drive:
