mattmtbman
Ok so I have a 2004 Tundra 4x4 Double cab with what seems like a limited slip diff when in 2wd, but when I shift my transfer case into 4x4 the Limited slip seems to disengage. I tested this by jacking up the rear end and spinning one rear tire, in 2wd both tire spin forward then when I shift 4x4 one tire spins forward and one spins backwards. Has anyone else experienced this or figured out a way to make the limited slip work in 4x4?
