4 Wheel Drive and Sport Utility Magazine reports the following:
"Jeep Performance, a division of Mopar Performance, is working on a stand-alone diesel engine swap kit to drop the 2.8 diesel that first appeared in the Jeep Liberty into your TJ, YJ, CJ, or ?
While we'll have more details (and maybe a photo or two) after Jeep Safari in Moab, this is the real deal and is going to happen. Everything needed to install the diesel mill into a Jeep will come with the kit - including a stand-alone wiring harness and non-EGR motor! "
http://blogs.4wdandsportutility.com/6232286/editorials/diesel-jeep-swap-kit/index.html
Presumably the kit also has some recommendations for upgrading the front suspension. The VM Motori 2.8L diesel is about 175 lbs heavier than the gas V6 in the Liberty.
I guess this means you can have a diesel engine in your AEV Brute conversion of a Jeep TJ!
Chip Haven
Chip Haven
