2-Dana 44 axles, 1 front, 1-rear
brushogger
I hope this is the correct location to post this since they are parts and not a vehicle. If not, please let me know.
The front Dana 44 axle is from a 1982 full size Jeep Wagoneer. Disc brakes. it has the stock gearing which I believe is 3.23 or close to that. When I removed it I cut the brake lines and pluged them with screws to seal up the calipers. The rear dana 44 axle is out of an Isuzu Trooper. It has drum brakes and 4.56 gears. The spring perches were removed for a spring over conversion. I will take $450 for the pair. Local pickup only. I am in the process of moving and can't ship them. I can be reached at 405-570-6659 or emailed at phoneman@swbell.net. I am located in Norman, Ok.
