2000 dodge ram Built
blue dog
2000 HO 6 speed nv 5600 SLT leather sold sold sold sold.
$12k as she sits
220k, 100 horse custom injectors, edge ceramic ball bearing turbo, edge comp box, fass 150, egt and boost gauges, 4" exhaust turbo back and turned down before axle, BHAF air cleaner with kenworth tubes. custom bed cage{ 2" } with 14" 2.5 triple by pass, shocks double sheared top and bottom, bottom is off of center of leafs, fox bumps in rear, frenched into the frame,full deaver race leafs built to my spec. kore towers, race sway bar, vr coils, 2.5 fox up front, fox stabilizer, all shocks just rebuilt 1 month ago. , custom 10k lb hitch up front,12k in the rear. warn quick connect jumper, rear work lights in bumper as well as dust light.Stainless steel brake lines front and rear, bigger slotted rotors up front. Injection pump is one year old, replaced starter and alternator 1 year ago. 14 travel in the rear limited by bumps, 9 3/4 front. Leather interior, power seats, upgraded stereo and speakers. NV5600 trans and dana 80 rear end. This was a special order truck, rare configuration. There are not many 2500 quad cab 6 speed dana 80 trucks. Truck is in the 450 hp range, over 900 ft lbs of torque.
Truck has slight body damage on quad cab door and above wheel well on driver rear. Truck is due for a clutch and brake pads. Heater core is by passed, i have a replacement heater core, Heated seats do not work, i have not looked to see the issue as of yet. Front abs line is cut but i have a new one from mopar to install. cruise control needs new vac line, a complete PSC box and hydro ram set up new in the box comes with the truck. This truck has never left me walking, all the fab work on it is top notch.All parts are top of the line. This is a good strong truck that just needs some love, camper shell with extra height. Excellent baja truck, chase truck or adventure truck.
Pics can be seen here.
http://www.flickr.com/photos/desertbluedog/
EXP-T100
Bump for a sweet Ram, where were you 6 months ago your truck is just what i was looking for but i ended up with a 3rd gen. someone is going to get a sweet deal on this one.
Saiyan66
I know it seems like all the good trucks pop up after you have just purchased one. Good luck with the sale. You shouldn't have to give her away with the popularity of pre-smog diesels nowadays.
blue dog
thanxs
Thanxs for the comments guys, what i am asking for the truck does not even cover the cost of all the after market parts and fab work. This truck alone will blue book out at $9500. Just time for a new build and something a bit different, yet still using a ram 2500 4x4 with the cummins of course. My goal is to build a truck that can perform about the same as this one, yet keep her at factory ride height, just leveled. Have already started on having custom coils and spring under in the rear leafs designed. She is a great rig, just needs to go to someone that knows what it is. Expeditionxterra is going to come by tomorrow and take her for a spin. Turns out we have friends in common. Small world
flipstick
