Mike Serpe
$49,000. 50 state certified/CA legal
Why? Because so much was spent on going through this truck. Review the list.
Modifications
HD Steering Components including new steering track bar and tie rod, new stabilizer shock
H&R billet aluminum wheel spacers
Thor / Viking Suspension with 3 inch lift includes Heavy Duty shocks
High end stereo, with bluetooth integration.
Burl walnut transfer case knob added by Europa in 2018
463 rubber mats front and rear seating areas
Original light gray Headliner sagged, so was replaced with a Black alcantara headliner.
Repair or Maint in last 1k miles by Wolfgangs and Mike Serpe
Recent brake caliper work, brake lines, ABS pump, new pads, rotors
Service (lube, fluids, filters)
Wolfgangs just tuned up the engine with 16 new spark plugs replaced two weak coils found by way of running full computer SAMS/ECU diagnotic with Star and Xentry. Noted that car runs like a new one at time of service completion. Has been significantly road tested.
3x Differential locking system serviced and fluid flushed.
Brake fluid flushed
Door locks were inoperable, so all doors taken apart and door lock actuators repaired or replaced as needed
Repair or Maint. in last 10k miles
Complete Front Axle Rebuild managed by Europa Russ / JR all diff lock system parts gone thru and replaced, This included new CV joints, bearings, seals, boots, grease, kingpin bearings, hub nuts and washers, CV grease. Large list of additional work.
33" Toyo All Terrain Tires
3x New driveshafts from Mercedes
Suspension bushings
New valve cover gaskets due to drip found on one side
Replaced Timing Cover Expansion plug due to small weep found
Replaced starter
History
Previously a Miami and Los Angeles car.
Lenny and daughter Zoe Kravitz, original owners had it and loved it in these two locations for 18 yrs.
contact Mike at
mserpe at yahoo dot com
Modifications
Brake fluid flushed
Suspension bushings
Replaced starter
History
contact Mike at
