2000 Ford Econline w/ UJOINT 4x4 Conversion & Custom Interior Build
bkbroiler00
2000 Ford Econoline w/ UJOINT 4x4 Conversion (2016).
“Ida Vanning”
  • 5.4L V8, ~340,000 miles and going strong! (odo is off slightly due to the shorter gearing, even w/ the ECU adjusted). Various parts replaced as needed (FI rail & injectors, coilpacks, radiator, serpentine belt at least once)
  • 4R70W transmission, rebuilt 2019 along w/ T-Case adapter. AutoMeter tachometer. 4:56 gearing, LSD rear, open front w/ SpynTech hub conversion and Mile Marker lockouts. Solid axle diff covers F/R. Bilstein 8100 (I think) shocks.
  • 6” lift. LT315/70R17 (35x12.5) ******** Cepek offroad tires. Maybe around 5k miles on them.
  • Full insulation (DynaMat, Denim and Reflectix), custom windows and interior build.
  • 100w solar and 100aH battery Renogy system, tied to alternator w/ isolation solenoid.
  • OBA, solar shower, roof box & basket, ARB awning, Baja Lights, slide-out cooler drawer w/ 12v plug in, sink (can’t find pump filter cover), Hi-Lift Jack, tire chains, dangly balls & ivy string lights.
She’s got a few known issues:
  • Rust spot finally made it through the driver’s front rocker. Paint chipping on driver’s front fender. Dent along the driver's side mid rocker and up by the B-pillar.
  • Front end is squeaky, I think it needs ball joints. I have replacement Heim joints for the track bar. Rear springs are a bit saggy.
  • Slider door handle recently stopped working from the exterior but works from the inside.
  • Neutral safety switch doesn’t always align so sometimes the shifter needs a jiggle or put into N to start. (I have the replacement part).
  • One of the roof rack mounts cracked. I have some steel ones I bent up to replace.
  • One awning leg is bent, still functional, just doesn’t store in the awning.
I’m sure there’s a few things I’m missing. This van will get you looks and get you out there! Built it for extended desert/Baja living. Never thought I’d sell it and now I have different needs so on she goes. #LookI’mOverlanding
Located in Salida, CO. Asking $33,000. She’s got a lot of life and adventure left in her! Call, or text Bryan with a message that only a non-scamming human would say.
3oh3. 2wo seis tree. Fortyniner7for.
Don’t need help selling. If the ad is up, it’s for sale. Will not respond to “is this available.” Serious inquiries only, please. Thanks for looking!
Wherever you go, there you are.
  • Like
Reactions: zip
gp01
