2000 Jeep Grand Cherokee (WJ) Laredo, 4X4, 74K Miles, 4.7 V8, Automatic, Selec-Trac, A/C, PW, PL, Sun Roof, AM/FM/Cass, Cruise, Tilt, Quadra-Drive Axles With 3.73 Gears, Floor Liners, 265X75R16 BFG All-Terrain Tires W/Full Size Spare, 4 Inch Iron Rock Off-Road Suspension, Bilstein 5100 Series Shocks, JKS Quicker Disconnects, JKS Shock Absorber Bar Pin Eliminators, Addco Rear Sway Bar, Rear A Arm Spacer, All New Coil Spring Isolators, Adjustable Front Track Bar, Custom 4X4 Fabrication Rear Bumper/Tire Carrier, Custom 4X4 Fabrication Front Bumper & Winch Mount, Rocker Guards, Off-Road Package Slid Plates, Amsoil Air Filter, Newer Wrangler TJ Wheels, PIAA Fog Lights Front, Aux Rear Back-up Lamps, Tom Woods Rear Drive Shaft, Factory Tow Package (6500lbs).
Extras: Set of five factory aluminum wheels. Replaced original headlights with new factory headlight assemblies and installed clear 3M protective covers. AirAid open cold air filter. Original Quadra-Drive Transfer case (makes noise) and drive shaft. Two new key fobs.
Daily driver, ready to go cross country or to local trails. All mods performed in the past year and last 10K miles. I drove cross country Summer 2010 and it was a very pleasant ride in a capable Jeep. Most recently, I swapped the Quadra-Drive transfer case out for the stronger Selec-Trac transfer case. Mobile 1 synthetic engine oil used since 50K miles and synthetic in drivetrain. All maintenance records are available. Clean title with no accidents. Family situation drives sale. Located in Maryland. $8800 OBO. Call 803-795-9567.
