2000 Tundra DIY Truck Camper $8,500 obo
Dirits
Price: $8,500 obo
2000 Toyota Tundra 4x4 Access Cab Limited
Two owner (first was father-in-law, first 285,000 miles)
Current mileage: 320,000 miles (will go up slowly as this is my daily driver)
Description:
This is my daily driver and family adventure rig. It has been incredibly reliable and although has plenty of miles on the clock, I would not hesitate to drive on an adventure. The only reason I am selling is because my family of four has outgrown the access cab. Despite showing signs of prior life with my father-in-law (small scrapes and dings) this truck has been maintained and taken care of. Whenever maintenance and repairs were needed to be done they were completed and other items were upgraded.
In 2017 I wanted a platform that I could adventure with my family in so I built the camper on the bed. The weight of the camper low, 450 lbs (including windows and solar panel), due to a composite construction technique. It has sliding screened windows on both sides and an awning. It also has a 100 watt solar panel on the roof and two pop-up vents with 12 volt fans. The top of the camper lifts up about three feet to create a queen sized sleeping platform above and a shorter platform below for gear or children sleeping space. The camper functions great as a camper shell and would benefit from a complete interior build out as well as new canvas for the pop-up. The roof and windows were resealed Fall 2022. The combination of this truck and camper has been great and is sure to be a conversation starter wherever you adventure.
This truck needs a new home and an owner that is ready to take it to 500,000 miles.
Upgrades:
-Bilstein 5100 shocks Front/Rear
-Hellwig Helper Spring, Rear
-Upgraded Timbren Rear Bump Stops
-2 inch receiver
-Front Seat Covers (driver side showing wear)
-Bed liner
-DIY Pop-Up Camper
- 100 watt solar panel
- Solar Charge Controller with USB and 12 volt output
- 12 volt house battery (needs to be replaced)
- two roof vents/fans
- two sliding glass side windows with screen
- roof pops up to create sleeping platform above
- soft siding of pop-up is tarp material (functional but could be replaced)
- retractable side awning
Recent repairs/maintenance:
-New Radiator and hoses ~290,00 (receipt)
-Brakes Front/Rear ~295,000 (receipt)
-New Tires ~300,000
-Timing Belt and Water Pump ~300,000 (receipt)
-New Starter and Battery ~305,000 (receipt)
-Spark Plugs Replaced ~ 305,000
-Steering Rack/Tie Rods/Carrier Bearing/Alignment ~315,000
-CV Axle boots both sides ~318,000
-Front Differential fluid change ~318,000
Known Issues:
- Scrapes on hood other small scrapes on truck body
- Fender Flares showing signs of clear coat peeling off
- Driver side seat/cover showing wear
- Driver seat belt light flashes intermittently
-CD/cassette player do not work (I use a bluetooth FM tuner to connect my phone)
-Missing driver side front mudguard
flipstick
